In the process of tuning rb20det to standard specs. car is very slugish on standard base ignition timing also has been converted from auto to manual running standard auto ecu.
car has following mods
-unopened rb20det
-rb25 turbo
-walbro 255 pump
-pod with custom box and air duct
-12psi
-fmic
-3" exhaust no cat strait to rear muffler
-yellow jacket coil packs
-new iridium plugs gapped down to .8 from 1.1
i put the timing to the auto's 20 deg btdc with aac unplugged and idle @700rpm like this you put your foot down and it makes alot of noise but isn't pulling very well compared to if its on 30 deg btdc which it really gets up and goes (with no pinging). 20 deg, kick cluch in second will bog! 30 deg kick in second lets loose and abit of third? do i have to maybe gap the plugs back to 1.1 to bring ignition back to 20???
https://www.sau.com.au/forums/topic/392159-slugish-15-20deg-timing/
I assume your using the wire loop at the rear of the engine? Cheap timing lights tend to read double or half while using it.. i can't remember. Best place to get a timing signal is from coil #1
DOUBLE. So you probably only have 10 BTDC.
Most accurate is to insert a spark plug lead between #1 coil and #1 plug, and time it "old school".
You are running good coils and fairly stock power, so I would suggest you open the gap back out to around 1mm.
timing was done with ignition lead between coil 1 and plug. also just moved it to 25 and i can live with thepower it has there but any thing under and its really boggy till your up around 6000rpm. This is all assuming the orange mark is 0 and 7th mark is 30 btdc?
Edited by domo88
my thought is if i make the spark gap bigger it will ignite the fuel quicker therefore i can make it fire closer to tdc (more retard) at the moment the spark is weaker and to ignite the fuel properly its having to fire that much more early or advaced. does this sound right?
no worries well its running well where it is and not pinging so i'll leve it there till i get money for nistune and get it on dyno. also when i had the timing backed off it was super fuely and poping when going down gears wich is nothing different when running rich but when i was pushing the accelerator and was running slugish and bogging down at 6000rpm it hit fuel cut??? my theory is that because it was running so rich the computer tryed to compensate for it by trying to correct a/f mixture with more air and maxed out the afm making it hit fuel cut??? this is possible? coz hasn't done it since got it running right... cheers for replys
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
