Group Buy, New R33 Front bar.
  • Replies 54
I am very interested, but would like to see a picture of it on a car to be sure.
Dont take this the wrong way, but what is the quality of the bar like? My car is beeing painted by one of the top (most fussy) painters in SA, and if it dose not sit in correctly, or isnt straight he wont touch it. (dont want to waste your time and money shipping it back to you)
I am going to pair it up with an impule bodykit, but I am unable to get a front bar at the moment (nor for the forseeable future), hence the need to look at alternatives.
PS what would it cost to ship it to Adelaide? (in the next week (2 weeks at the most))
Guest MFX_R33
My car is in pieces at the moment (and has been for 8months) and wedged in a corner, so you wouldn't see much.
As for the aero dynamics, the bar is designed to give a good amount of front downforce, and is also designed to go with the carbon fibre cannards we are currently finishing off.
The bar is also designed around a 600x300 intercooler, so you can receive maximum flow.
Jeff.
i just wanted to know where u tested its aerodynamics. as to do this properly you would need to put it on a car then put it thru a wind tunnel you would also have to put the original car in a wind tunnel to see the differences in downfoce. Only monash clayton has these facilities in australia. the wind tunnel their goes to 200 km/hr. and its very expensive to hire...
dont want to start a nerd-fight in someone elses thread - but you sir, are a goon!
Guest MFX_R33
No we have not tested the bar for exact aero dynamic properties. As I said we have "designed" it to give a greater amount of front down force, using the wing shapes on either side of the bar, and as I mentioned before, with the optional carbon fibre canards.
If someone on here wants to know the drag coefficeint of the car before and after the kit, they would be hard pressed to find it for any kit. This factor will also change for most cars at any rate, as it depends on may other factors as well, including ride height, and the other aero parts they have fitted to their car.
This said, most people buy body kits for purely cosmetic reasons. We are offering an alternative to the limited range of R33 kits available in Australia. There are very few companies in Australia producing NEW stuff. If you like it that's good, if you don't that's fine too. We are just offering you guy's another choice.
Jeff.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
