Hey Guys,
I have a G3 sitting at home which I am eager to fit it problem is i am having trouble trying to find a fastener shop that has M10x1.25 x 60mm bolts/studs with at least 60mm or thread length. Long studs are needed as the G3 requires a manifold spacer.
I have tried:
Cedray Silver water
Coventry Fasteners
Tri Fixx Granville
Lee Brothers Parramatta - Only have 1meter rod for $60 - Will use as a last resort.
What did you guys use when fitting your G3 to your RB25 manifold?
https://www.sau.com.au/forums/topic/392605-all-hypergear-atr43-g3-owners/
Buy this from supercheap or autobarn
Grind the hex head off, and you have the stud and the nut.
Also there is a rear housing update on all G3 units which I'm happy to carry it out free of charge. check my thread for further details.
