f**k im gona bash mu cat gutless next tune, its a 100cell metal item tho..
Can you try dropping the exhaust first? I have a Venom 100 cell metal cat and would be interested to know if they do significantly reduce power. I believe they don't but hard evidence would be good! Need the cat for a cert but if they cost 50 -60 hp its days are definitely numbered! So far my RB30/25 is only making 220awkw at 15psi. I have been concentrating on fixing the oil control problem but have nearly sorted that and will concentrate on finding the power ( will be going to 18 -21 psi but should be making nearer 300kw at 15 psi :(
This too. My car is down about 50rwkw and we suspected the intake. Ive fixed that up but really hope my cat isn't the issue...
I have had a lot of catalytic converters drop power these days.
Sarge did we drop the exhaust on ur car when tuning?
What cat is Stao running?
We didn't drop the cat, Wolverine on here runs the same cat and makes the predicted power with his turbo as do a few other members. These 5" body venom cats only have 100 cells in a massive body so should be better than most cats. Send me a PM, I'm ready to bring the car back up to you when you are ready(just need to change my AC belt, its squealing and tearing lol). Stao doesn't run a cat...
My car has lost about 85hp at the wheels, thought the motor was getting sad, but got the leak down test an compression test done both came back fine. tune still seemed good just missing power (from 385 back to bout 300)
wondering if anyone had any ideas wot it could be? thank in advance :thanks:
Was both results on the same dyno?
alot of happy dynos out there haha
i have one running just shy of 400kw
ERD have had people making 400+ using them.
http://www.skylinesaustralia.com/forums/topic/379675-when-does-a-5-cat-become-a-restriction/
Have u tried a run without it to see the difference?
Does anyone else picture a furry little cat clinging onto the bottm of the car for dear-life? Lol.
I used to have a nismo cat. Made 252rwkw. Dropped it and put in a de-cat pipe.. Made ~262rwkw. Silly mistake.. Should have kept it on. The power gain barely (if at all) justifies the legal issues.
  • 3 months later...
I Had a 3" metalcat, tuned with it...then gutted it, ran it on the Dyno and we could add more timing without it knocking
Have since added big mofo front pipes and 3.5" decat - 3.5" cat back
Dead cats are good cats :)
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
