Location - 181 Reynolds Road Doncaster East VIC 3109, the pines shopping center, corner of Blackburn road and renolds road east Doncaster (car park location outside nandos)
Date/time - Friday 9th March 10pm meet for a sharp 11pm take off
Destination - will be the usual route (guys that have come along know where I'm talkin about) will be revealed on the night just bring a full tank of petrol
For all you first timers, come along were all a friendly bunch of people and enjoy talking about cars :D
Please be on your best behavior especially at the meet points...see you's all then!
https://www.sau.com.au/forums/topic/393049-cruisemeet-9-3-12/
  • Replies 48
Awesome, not sure if I've got anything on that night, but I'll certainly try and make it, will probably let you know closer to the date. Loving the route too, lots of great twisties. Want to practice up a bit more and hit them tighter :D
Being the Friday of the labour day lond weekend, do you think there will be a lot of people on the roads going away for the weekend?
Labour Day is on the 12th March for VIC.
The 5th March is for WA.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
