  • Replies 123
Posted Images
Jay I just love your creativity and finding and using what you have rather than spending money on the latest and greatest thing. You have a great eye for photography mate.
Dan - f2.2, iso 2000.. Canon 85 f1.8 (cheap lens). Hope this helps. Lighting - 580exii.
owen - Ooo nice sunset there :)
cheers dude. i dont have money to spend on the latest/greatest but thats not really such a bad thing. came up with an idea to make the rig more stable. going to give it a try today and see if it works out.
sorry, double post.
tried a different kind of rig mounting. still needs something to make it more stable. with access to materials and the right tools I reckon I could make it solid enough for my G12 to get slower shutter speeds happening.
GoPro has a set aperture, can't remember what it is though. Pretty sure it's 130° angle. I bought one a couple of weeks ago, absolutely love it! One of my best impulse buys :P
Here's a quick time lapse I made with it, please excuse the shitty editing and my horribly ugly mug! I'm working on my editing skills, but I doubt there is much a can do about the face!
I'll upload some photos when my Internet isn't 20gb over my cap!
Edit: I can't embed it on the iPhone :(
Edited by NA_Goodness
yeah, like NA said, its a set aperture and full auto exposure. It has a 170° angle so swapping to another camera would mean less of a view. it was fun to do but i dont think i'll be doing much refinement on it. ultimately having a full quick release setup would be nice as its a pain to get in and out the house and to unbolt, lol. i can picture in my mind the kind of hardware i would need to make it better, but its a cost i cant justify for a few shots. i have a couple of other projects that need to be finished first.
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
