  • Replies 107
Thanks heaps guys. I hope this has put the knockers bullsh1t to rest once and for all! :(
Funny how i havent heard from ANY of the guys that gave me sh1t 6 months ago about installing the nitrous kit?!!??! :D
I have pulled most of my site down but if you click the Specs link at www.2rismo.com you can see what's been done to my car.
Adrian
So just to clarify, you did 13.4 with the mods listed on your webpage, down to 11.9 with just adding nitto's and the 75hp nitrous?
Actually did a 13.0 @ 108 mph with gas and normal tyres.
And you did 12.5 just from adding the nitrous, and running regular tyres?
Yes.
Adrian
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
