How's it going guys my rb25 blew last summer the timeing belt broke mashed the head up and broke a pistion so I finaly have a new head and the money to rebuild the engine. I'm from the US but the fourms here suck as far as rb knowledge goes. So I'm shooting for 500rwhp in a s13 this is a list of parts I plan on useing to get me there if you all could let me know what's needed and what's not or a better way to get the best bang for my buck let me know thanks in advanced. Arp head , main, and rod studs / acl main and rod bearings / isis intake manifold / either cp or wisco pistons / and either eagle or manly rods / z32 Maf with a q45 throttle body / stock exhaust manifold with tial 44mm external waste gate / holset Hx35 / as for head gasket I'm looking at the cosworth or the apexi and I'm running a apexi power fc/ for fuel injectors 1000cc not sure if that's over kill or not please let me know / and I'm running a z32 twin turbo fuel pump
https://www.sau.com.au/forums/topic/394072-rb25det-rebuild-help/
You're going to be spending a fair bit of money so you'll want to get it right first time. I would suggest it worth your while to have a good read of this thread:
http://www.skylinesa...s-engine-build/
My only quick suggestion is that for 375rwkw you will want something better than the stock exhaust manifold e.g. a 6 boost or a Sinco customs one:
http://www.sincocust...20Fabrication/2
http://www.6boost.com/
Also have a read of the thread at the top of this page: dyno results for RB25 upgrades
http://www.skylinesa...l-dyno-results/
Guys in NZ are getting good results with Holset turbos but I don't know the capabilities of the one you are proposing to use - what is its mamimum output? And is the fuel pump brand new? I would want a new pump such as a Denso at least.I would prefer a more modern ecu such as a Link but if you already have the PFC it will be fine.
Recommend reading the dyno thread and seeing what similar people have used to get their results. Remember your 500hp is generally less than ours, also not sure if you guys measure at wheels or translate to at the flywheel, but take that into account.
To (kiwi) the max output of the holset is 60lb/ per min the trucks they use them on run 32psi all day so I figured it would work for what I'm wanting and I do plan on going with a 6boost I'm waiting for a group buy to come up or one for sale on our fourms here in the us.
To (rolls) most of us dyno our cars at the wheels but I do know our HP rating seems to be higher than most other places I just figured we tac on the extra HP for the amercian ego trip lol.
A truck engine isn't a skyline engine. Totally different rev range, flow rate, pressure ratio blah blah.
Read the dyno thread, see what worked for other people and duplicate it. Garret gt3076 is good for 300kw ish which imo for a 2.5L would be the max you'd want before the lag starts to get serious. You can do that on a stock motor, or a built motor with cast pistons if it is tuned correctly.
If you want to build a motor just buy a full rb30 from rips, do it once do it properly, 3L and it will probably cost almost what you'd pay to rebuild yours a few times after the first time it grenades because the builder wasn't experienced.
Ok (rolls) I under stand that but please look into the holset for the price of it you can't beat it I've researched it many times that's why I went with it!!!!! I'm sure I will change the turbo when I can afford one but then again I don't want my car to be a dyno queen
What research did you actually do?
The holset is possibly the laggiest turbo for the power you could use...
There are NO decent results around anywhere that I've seen. I remember doing some digging mid last year as someone else from the US was wanting to use one, all the results were just ridiculously laggy and they were on 3ltrs (2JZ).
Seriously? I've seen and know people who have got awesome results with HX35s... from WAY back, if I could talk to the guy I was in 2006 I would tell myself that my initial preference of going an HX35 on an aftermarket manifold instead of the the internal gated stock mount GT3076R for slightly cheaper would have probably been the better way to go.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
