Hey, helping a mate do an engine conversion in an R34 GT-FOUR. Initially thinking of an RB26 or RB30/26 swap but the big concern is the level and complexity of the re-wiring that might need to be done to get the 26 loom spliced into the 34's existing loom.
We want to have the car off the road for the minimum amount of time possible.
So queries are:
· Would we be better off ripping the 25 loom out and replacing with the 26 loom?
· Can we somehow use a mixture of the 25 and 26 looms?
· Or should we instead go with an RB25 or RB30/25 so that the wiring should be easier? On that note, is there a huge amount of difference in the wiring looms between the 34gtt and the 34 GT-FOUR (i.e. non-turbo)?
Cheers,
Peter
https://www.sau.com.au/forums/topic/394142-r34-gt-four-engine-swap/
Not a big concern. People can install 25DET neo into an R32 and use the RB20 loom with a few simple modifications to the loom AFAIK
I dont have the info for you but if this thread goes unanswered after a few days i would suggest posting this thread in the forced induction section and you will get the answers you seek. Also there may be some threads that already have the info you need hidden in the depths of this site.
25 is easiest.
but yes you can use your 25 loom for the 26 conversion, bit of splicing and dicing to do.
just download an electronics pinout for the rb25 ecu and then compare it to a rb26 one. then re arrange the wires accordingly. might also need to check the voltages for a few small things.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
