How old are u slylinerz???
  • Replies 241
29 here......
I dun think skyline pulls chick... even I overheard one chick at a bbq said "that red skyline was a bomb", how can she compares my baby with old bombs that you get from rent-a-bomb car rental?????
I wanna throw her on the bbq plate, cook her n eat her liver..... and.....
But all is not loose: Skylines does pulls blokes & turn blokes' heads...
Verdict: If you wanna pull chicks forget skylines. Get New Beetle, get new Mini Morris, get BMWs, or Mercs or any convertibles like Holden Astra convertible or even dodgy styled Renault Megane **yuck**. Unless that girl is a performance car enthusiast as well...
will u be celebrating on the nite cruz or somewhere else... imagine some1 holding ur birthday cake while taking some corners....... may not be good paintjob treatment for the interior.... mudcake custom interior..... yeah.
Originally posted by funkymonkey
That's OK so is nark on Friday nights, cept he's 21
by day time im a mild mannered reporter for the local newspaper, hiding my buff exterior and identity by wearing glasses and baggy suit.
lol...
i was just stating that the thread states "How old are u skylinerz" and he was replying 16 as in hes the youngest.. but he doesnt have a skyline... :D
and yes... at work i have a lot of time on my hands... GO ADSL SUPPORT
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
