So please outline exactly what is different now that it is a DE+t...
The fact that you a swapping and changing parts between s1 and s2 when they are known to be different is quite perplexing..
rb25det s1 injectors
rb25det s1 ecu
What airflow meter?
Also get yourself a consult cable and a copy of Datascan or ECUTalk, check for error codes and see what is happening when the idle is hunting.. is it trying to chase the idle with the IACV? or is it doing it via timing?
Have you checked your base and cam timing?
P.S. building hybrid engines of this sort you really need to have a good idea of what the ECU and all sensors are seeing/doing otherwise you will just be chasing your tail when issues like this arise (such as you are now).
Hey Bro have you tried cleaning your aac valve system, i did this to my rb25 on the weekend and car idles were it should, use to idle round the 2k mark,
im not sure if you have a "pulsing idle" as goes from 1500 to 2000 and back and forth, also check that your Throttle Positioning System electrical plugs are pluged in properly and not dirty?
just some hints that you could possibly try?
links below if you want to read more about AAC
http://www.skylinesaustralia.com/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/
Cheers
It's not AAC. It's IAC. ferchrissake.
Nissan Actually calls it an AAC dude.
Auxiliary Air Control valve. IACV is the same thing just worded differently. Idle Air Control Valve.
But Nissan call it an AAC valve.
Then there is the cold start valve which isn't controlled by the ECU, along with the FICD or Fast Idle Control Device.
there is actually 2 idle devices
aac - aux air control
and
iacv - idle air control valve
in r34's they integrated them but the aac i believe is the one under the manifold that brings the revs up when you cold start, iacv is the one bolted to the back of the intake manifold
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
