The car is a 1994 R33 GTST (series 1) (located in the ACT)
I have owned this car since late 2006 as my daily driver, in that time it has gone from having nothing more than a pod filter and a cat back exhaust to what it is now.
The car has been regularly serviced in the time i have had it, and as of right now the engine has around 6-7000km since it was refreshed (Late July 2011 (by Proengines) and was initially built in august 2009 (by proengines) after the stock RB25 spun a big end bearing).
The car has ACT rego until Nov 2012
The car has been engineered for the RB25/30 conversion including all engine mods and aftermarket suspension (with full emissions testing you do not need to modify the engine in any way for rego)
The paint and bodykit are completely standard except a copy GTR rear wing and light up "SKYLINE" fascia above the rear bumper.
I have receipts for most of the parts or work done to the car including dyno sheets over time as it has been built up from its stock 130kw to its current 394kw
Mods list (i have probably forgotten a few):
Engine:
RB30 series 2 Block
R33 RB25DET head
Forged pistons (Arias 9.3:1 CR, oversize 86.5mm bore)
Cometic MLS 1.3mm Head gasket
Forged rods (Eagle with ARP bolts)
Grub screwed stock crank
Pro Engines extended oil pump drive
RB26 standard water pump
RB26 N1 Oil pump
External oil feed for VCT using T piece at the oil pressure sensor.
ARP main studs
ARP head studs
ETM high mount exhaust manifold
Synchronic 50mm external waste gate (plumbed back into exhaust but could be modified to a screamer without much effort)
ETM 4" Dump pipe
3.5" front pipe
Modified Apexi N1 3.5" cat back exhaust (this should pass RTA noise tests)
3.5” in/out 5” body 100cpi Vemom cat (i also have a 2.5" euro 3 emissions cat you can have if you want)
Garrett GT3582R 0.82 AR rear housing
Greddy Intake Plenum (genuine not a cheap ebay copy)
Q45 90mm Throttle body
600x300x100 intercooler (3" inlet and outlet)
3" mandrel bent intercooler piping
Alloy 52mm radiator
16" thermo fan ECU controlled
Balanced pistons, rods, crank, flywheel. (to within 0.1 gram)
ACL conrod bearings
ACL main bearings
Stock cams with VCT retained
NGK Copper spark plugs (0.6mm gap)
Yellow Jacket coil packs (also have stock coils spare)
Air-conditioning has been removed however i have all the parts in a box
Fuel System:
Nismo 740cc injectors
Bosch 044 fuel pump mounted in tank
Stock fuel feed and return lines
Stock fuel pressure regulator
Electronics:
Vi-PEC V66 Plug-in ecu (Map based, with 4BAR map sensor)
boost controled by ECU + solenoid (currently running 26psi)
Techedge wideband O2 sensor/gauge (hooks into the ecu for wideband o2 control)
Snow performance stage 2 Water Meth injection kit (currently running 51%/49% water/meth (turns on at 8 psi, full flow at 25 psi))
Drivetrain:
NISMO LMGT2 wheels 17x8 with 235/45/17 near new Federal 595 RS-R tyres on the front, 17x9 with 255/40/17 near new Federal 595 RS-R tyres on the rear (all 4 tyres replaced early feb)
Tien HA coilovers (includes height adjustment spanners)
Standard calipers, with slotted disks all round, EBC Yellow pads on the front and EBC Red pads on the rear
JJR Adjustable upper arms front and rear
Hicas Lockbar
Jim Berry full monty clutch
Gearbox rebuilt with new bearings, seals and synchros in 2009 as the 5th gear syncho was failing.
Diff has had 4mm total worth of shims installed, it acts like a locked diff currently.
Cars bad points:
Paint in general is not fantastic
Has had a couple of small bumps over the years (no crashes)
There is a small oil leak that had recently developed (few drops after driving)
Drivers seat does have a tear in the fabric
The car is currently making either a clutch or gearbox noise at idle, this does not affect how it drives but have been advised not to drive it until the gearbox/clutch can be removed and checked out properly, as such it is not currently being driven. - Fixed
Looking for offers of $23k or $20k if you want to take it as is (no silly offers people this car has had a lot more than that spent on it and is stupidly fast for the money)
The only cars i would be interested in swaps for are: BF XR6 turbo or Nissan Stagea 260RS
NO TEST PILOTS, test drives are for serious buyers only, this car is not a toy.
Anything else please PM or call/sms 0419302418
post-32350-0-85201000-1332140393_thumb.jpg post-32350-0-51605900-1332140403_thumb.jpg
https://www.sau.com.au/forums/topic/395232-394kw-1994-r33-gtst-act/
couple things i have realised i forgot to list in the original.
it has an ASR 6.5L baffled/gated sump and aftermarket valve springs.
it has a side head oil drain and and extra oil return fittings welded to the sump (everything that returns oil to the sump has its own fitting, no T pieces or Y joins)
Has adjustable upper arms front and rear
Stereo setup, Eclipse head unit (fairly standard cd/mp3 support), 4x mids, 4x tweeters, 1x 12" metal cone elcipse sub in custom fiberglass box (running off a 760w RMS amp)
The water meth setup has a boot mounted 9.5L tank (this is enough to do quite a few laps on most tracks before you will run into surge issues (gravity feed into the pump))
few more pictures
Light up "skyline" logo on the rear
post-32350-0-93268800-1333175934_thumb.jpg post-32350-0-76825700-1333175989_thumb.jpg
Water meth setup in the boot
post-32350-0-06469400-1333175947_thumb.jpg post-32350-0-97406800-1333175959_thumb.jpg
Sub/amp setup
Block with the head off a few years ago.
This issue has now been fixed.
  • 3 weeks later...
  • 3 weeks later...
    • EMU Classic. For what I need it to do I see no reason to upgrade. Link and Haltech would both cost an extra chunk of money for a lot of unutilized features
