Hey Mark, how much longer do you think it is fair to make me wait for the money you owe me?
I did you a favour by sending your chassis brace to you with NO MONEY UPFRONT and this is how you repay me?
Of all the people I've had dealings with on this forum; you are the ONLY one to do this.
Get your sorry arse to the bank & sort out your affairs; I do not appreciate people taking advantage of my good nature.
quoted because i dont like my friends being taken advantage of
