Too bad Mark.
A neighbor of mine in the UK used to have an old Cedric Wagon.
You know you will get a lot more backpackers in a wagon than a sedan :whistling:
Get a Stagea.... Shame the Axis 350S cant be imported. I want one.
Are you still in Melbourne? Shout out if you want those headlight sockets or they will be thrown out.
Na mate dont need them anymore. All sorted.
But i do wanna say a massive thanks to scotty for helping me with the motor swap. It was a massive gamble and with all gambles therei the chance of failure and that whay happened. So the motorswap didnt happen and we kept the car NA.
Scotty worked wonders and the car is amazing, cleaned plenum and intake and heaps of other things.
Big thanks. Staying in room 35 was awesome.
It was also good meeting some of the VIC stag owners and their whips.
So there is not much i can do performance wise so im just going to enjoy it how it is now.
Now wearing a blue (BW5) aero front and soon some new wheels
Pics up soon!
We went through about 20 cans of degreaser/carb cleaner, as well as 4 odd litres of concentrated liquid degreaser. Damn those DD engines are dirty inside. Glad the det's don't have egr recirculation.
Hands were almost eaten away by the degreasers, just a normal day for me. lol.
  • 3 weeks later...
So i have 2/3 aero on the car. Buying a sedan rear bumper with aero lip on in QX1 - winning!. Problem is it can only go by sea unless i wanna sell butt hole to DHL and let the rape me on price.
Rest will be painted to match along with the mirror bases painted in a glossy piano black finish to match the B-pillars and also the foglight blanks and bumper mesh in the same black.
After the Rays wheels i bought off same will be refurbed.
  • 3 weeks later...
Ok so the VQ25DET engine swap didn't go as planned. Partly because of my lack of research and comparing cars and their differences.
So attempt number two is in the early stages of thoughts/planning.
I'm keeping this close to my chest.
This will be a long painful road.
Once I have the donor car it's down hill from there which is pretty common. The conversion kit from the states includes custom sump, engine mounts, transmission mounts shifter plate and a single piece tailshaft.
If that's not a clue I don't know what is.
  • Like 1
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
