don't have to answer the 'what do u do?' question. i found some thread about a White R33 GTR hitting u a little while back. explanation in there. I really need to get into property/shares. i've just saved and had it sitting in ING, and now got some ANZ shares (only cos i work there) but that's it. which do u think is a better place to start, property or shares?
cheers
  • Replies 53
Hey Daniel, yes it was the respray r34 gtt in melbourne, it was origianlly black I found out all its history since it hit oz, it had right hand guard damage which was replaced, I only know that some dude wanted that color r34gtt so they resprayed it to order... bloody good job they did, I didnt pay 37 though...
cheers
If you have the funds and a good credit rating, then going into property investment is a great idea, but i would wait alittle longer for the property prices to go down, they have pretty much peaked and sooner or later, the values will drop again. Just makesure you get good enants. I would recommend Toop&Toop property managers.
As for shares/stock bluechip shares are always a good investment, thats if you dont want to spend the time to research the markets, gold holding companys are always great giving high yeilds and capital gains at the moment. If you have a share $15,000 or so i would recommend buys Hilman gold shares, they have another float coming up in about 6 months, i've always got amazing returns from them. But i'd see how the market and dollar goes in the next couple of months.
You don't want to get burnt! :wassup:
the paint is not black its the gtr deep purple on my car, my car was 38k a year ago, which i thoyght to be a good price, because you cant get r34's into the country at the moment they are holding their price very well.
ive seen them between 32 and 44k, i will sell mine in a year and then buy a gtr r34... i think.
I've found the lines to hold their price better than most other cars at the moment.. Hell even the R32's.
Years ago I bought a VS V8 5speed IRS,SRS,ABS,FE2.
That set me back 24k. Sold it a year later and lost $8000. :)
choice A, by a standard commodore for 35 grand, then drop 10 grand in 2 years on it or...
Choice B, by an r34 turbo charged animal machine, at the right price... have lots of fun for 2 years ad mabye drop 3-4 grand....
Choice C, Crash r34 into stobie pole, spend the next 2-5years paying off the damages! No i have'nt crashed my car!
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
