It's DECA time people
At at this time we once again ask for your assistance.
For this event to run SMOOTH on TIME and SAFLEY we need a small group of volunteers (Officials ) to
Help out in 3 sections in the morning and 1 in the afternoon.
All Oficials on the daywill be supplied lunch and drinks and go in the draw for some great SAU gear.
An Officials breifing wil be held before the drivers breifing so all Officials will need to be at
the DECA complex by 8.30 am on the Saturday morning.
So if your thinking about coming up for a look and not competing this is a great way to get up
close to the action. Also if you are competing and bringing a friend or 3 it would be great if
they could put there hand up to help out on the day.
So if this sounds like you or your friends post up in here or send me a PM and i will your names down
Cheers... WayneO
MORNING
LONG WANG
STARTER..
TIMER....Kieran
FINISHER
SPOTTER
SPOTTER
MINI WANG
STARTER...Andy
FINISHER..Colin
TIMER.. Juliette
SKIPPAN
STARTER..Wayne
TIMER....Russell
FINISHER..Martin
AFTERNOON
SKIDPAN.
STARTER..Wayne
TIMER
TIMER
FINISHER..Martin
FINISHER
https://www.sau.com.au/forums/topic/396029-deca-officials/
Can I just mention that last DECA's severe lack of willing volunteers was very frustrating. It should never have to come to having to beg someone to help out - after all they're not paying to spectate the day and volunteering gets you much closer to the action.
If you are coming up and you're not driving, put your hand up to volunteer. You won't regret the decision. Hell, I haven't driven a DECA since '09 but I've barely missed one since!
https://www.sau.com.au/forums/topic/396029-deca-officials/#findComment-6292387
I thought last DECA we had too many volunteers? When I turned up with 5 of us ready to help we were told we weren't needed anymore.
Either way I should be able to help, just need to make sure no assignments are due around then.
https://www.sau.com.au/forums/topic/396029-deca-officials/#findComment-6294279
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
