Looking at selling works off my 33. Previous owner had them refurb'd not long before i bought the car. So in pretty decent condition not 100% sure on ofset. Believe fronts which are 18x9's are around the +25 mark and rears which are 18x10's are around the +30. Could be wrong will have to check but. Both front and rear sit flush with guards. And both front and tears have had fresh federal 595s fitted in past fortnight.
Can contact me on 0420986545.
Open to offers. Haven't got a set price as yet. Using my phone atm and cant upload pictures atm. Can mms pictures of wheels. Txt the above number if you want pic's
$200....this is not ebay...post an asking price as per forum rules.
width and offsets are stamped behind the wheel. Post them up if you want to sell them quicker.
Edited by n15m0
$352 With over night courier to Brisvegas? I want a brand new set of nismo wheel nutz thrown in on the deal as well plz.
I get paid at the end of November so send em ova and i fix u up in 8 months?
As it says up top its 'eoi'. Offset is...fronts +30 (running 5mm slip ons) and rears are +25. Feel free to make reasonable offers rather than clogging up the post with shit!
$354
And read the for sale rules- no EOI's- you need a price or this will get closed by Admin. Thats why people are dicking around.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
