oh Come'on Nowelly....
to add to that list,
Andrew Kuc - Pro Automotive Moonah, Hobart
Darren Anderson - Southside performance, Burnie
just because Kutzie "growled" at you once doesnt mean he doesnt exist. hater dont hate nowelly troll'ey
most Good mechanical/engineering guru's around hobart have been known to yell abuse and throw spanners pre coffee. suck it up
cool
however, nowelly doesnt think Pro Auto is not reputable, he hid in his box and sucked his thumb because he (Mr Kuc) is a tad 'gruff' at times, therefore it is my job/god given right to rag the shit out of nowelly, it's how we work. its just that kind of love.
sorry OP, back on topic.
p.s i LOVe u Nowelly
everyone has there own little horror's and bits of info about various tuners, one of my best mates is an engine builder machinest for a very reputable machine shop in hobart and some of the things these so called reputable tuners that have been listed have done (I have seen these nasty's first hand), uhh yeah. anyways its gone too far already,
good luck to the OP =)
I honestly forgot about Pro Auto this time.
I'm fine with Kutzie now, we had a good conversation :)
I'm hating on another workshop now for talking to me like I'm a child. Then it turns out everything he told me were lies anyway! But that's a discussion for another day at the Pub :)
Edited by zoidbergmerc
Or pro automotive who are about the same distance and have worked on the car before so could tell you more about it? . Not that i have any problem with nick or tas mobile , both are good friends of mine , was more of a joke , i would take it to nick at gt if it were of that could afford that car! And i have looked at it closely , it's nice!
Edited by toffy
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
