I've got an R33 GTR spoiler fitted to my R33 GTS-T which was done by one of the previous owner/s, I've purchased a carbon fibre wing blade for it. I Don't know if the factory ones come with torques head screws on the pivot and slider part, with the holding screws being allen keys but the problem is the torques head screws have been threaded and I cannot remove them. I've tried applying pressure to them and trying more so but I can't remove them.
Any help would be greatly appreciated! :)
https://www.sau.com.au/forums/topic/396227-33-gtr-spoiler/
from doing a little google researching Ive found out its a common issue and others have found that nissan used locktite on atleast one of the bolts either side...
others have drilled them out also...
any suggestions to avoid drilling them out?
https://www.sau.com.au/forums/topic/396227-33-gtr-spoiler/#findComment-6293999
I'm a bit against drilling them out also. I had a suggestion if there is a tiny bit of slack in the blade if it could be stretched and a hack saw blade may fit between the wing side and the blade to cut the bolts. Haven't had a proper look yet
https://www.sau.com.au/forums/topic/396227-33-gtr-spoiler/#findComment-6294008
Managed to get the old blade out by grinding back the head of the bolts flat then drilling into them to make them hollow, spacing out a gap between the blade and the side of the wing, masking up the area and running a hacksaw blade through the bolts. Problem solved for me.
https://www.sau.com.au/forums/topic/396227-33-gtr-spoiler/#findComment-6308461
