Hey guys,
So my R33 GTST came with the Active LSD system. Since I want to go drifting I ripped it all out and replaced it with a regular viscous LSD and just shimmed the fark out of it.
When bolting it back together I have run into a snag. The half shafts on the A-LSD are threaded so the bolts just go through the axles and into the half shafts.
The new half shafts are not threaded, so how are they set up from factory? Do they just have a nut on the end? does the end go on the half shaft side or the axle side?
Also the A-LSD had two sensors coming out of it...I think they are temp sensors or something, the new diff just has one.... Should I just splice the four wires into two and connect up the new sensor?
https://www.sau.com.au/forums/topic/396243-few-quick-questions-about-r33-lsd/
If you had ever experienced an A-LSD you would know why....may have been good when new but mine was downright dangerous for drifting...it would single spin most of the time, but every now and then it would just go bang and kick out... Eventually I'm going to get a 2-way but they can't go into the a-LSD housing anyway so I had to swap it out to the regular gtst diff. I just thought i would try and go with the shims first and see how it goes....if its shit I'll pull it out and drop a Kaaz or nismo in. I've figured out the bolts....all I need to know is what to do with the wiring..I'm thinking now I might just hook up one of the sensors.
Your description of your A-LSD's behaviour matches with my experience of VLSD behaviour. I've not driven a "shimmed" VLSD, but the thing you have to understand is that you haven't changed the way the viscous coupling works by shimming it, you have just transferred the load out of the coupling and into the wear surface outside the coupling. It won't last, it has to wear the diff out.
Now, as to your other questions, I'm pretty sure that the normal bolts through the CVs to the halfshafts have nuts on them, with the nuts behind the halfshaft flanges - you couldn't push a bolt through from the diff side anyway, no room to do so. Also, can you put up pictures of the sensors you're talking about? The only sensors I'm used to seeing on Nissan diffs are the ABS sensors at the rear. Oh, and the speedo sensor on the S15 diff.
FWIW, I've just built a diff for my R32. S15 helical centre, 4.11 gears. It has transformed the car (from a total POS with the original VLSD). It may not suit drifters (but then, I wouldn't have said an R33 was a good choice for drifting either), but I would never choose a mechanical plate/clutch style diff over a helical based on my new found love for the predictable way the helical drives.
So yeah it's actually an ABS sensor...the old diff had 2 and the new diff had one...I just wired up the one but the ABS light is on.. I know how the shims work and i know that its just increasing preload, but it costs $20 so i just thought ide try it first. Just went for a drive and the diff is tight as f**k...I think I might have gone overboard with the shims...it's making some weird noises and vibrations..
Hopefully it loosens up a bit..
Just thought Id update that shimmed diffs are shit..
It was super tight at first and made all sorts of f*kt up noises....after a week it has settled down and doesn't make any noises any more but it also doesn't lock up dualies all the time.
On the brake it spins both and on left handers it spins both but right handers it peg legs for a bit and then goes. It's heaps better than the A-LSD but i would just rather a locker. I shimmed the hell out of it too with 3.3mm total preload.
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
