hi guys i had a skyline and i had got pull over by cop for tinted windows..they give me a letter to ask me to make the windows lighter and i have bring my car to vic road...if i bring my car to vic road they will only check the windows or they will check my whole car??? and can u guys let me know where to remove the tinted windows with cheap price....thax guys plzzz help
https://www.sau.com.au/forums/topic/396397-got-pull-over/
If tinted windows are all that is detailed in the letter then that is all that Vicroads will check. You can remove tint yourself with a hair dryer, or call a tint place and get some lighter tint put on (they'll remove the old at the same time).
https://www.sau.com.au/forums/topic/396397-got-pull-over/#findComment-6296269
I've never had much faith in some cops ability to use the "tint meter"... ...I've had them get anything from 15 to 73... ...And that's just from moving from the right to the left... ...And then a 1/4...
If you've got dirty windows it can give a false reading... ...I've got stock tint on my 33 and it's even faded because you can see the SAU Vic sticker "shadow" after I removed them... ...And they still sometimes tell me it's too dark...
https://www.sau.com.au/forums/topic/396397-got-pull-over/#findComment-6296281
Did you ask them which windows at the time they pulled you over? It'll most likely be your side windows and probably the rear.
Your windscreen most likely won't be tinted...no tint place would do that for you because it's illegal to put any tint on the windscreen.
https://www.sau.com.au/forums/topic/396397-got-pull-over/#findComment-6296282
I got defect notice for tinted windows when i bring back to vicroad will they check for everything on my car or just the windows
The question has already been answered.
https://www.sau.com.au/forums/topic/396397-got-pull-over/#findComment-6296819
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
