Hey again all,
The previous owner of my 34 was a braille parker and one wheels has some serious gouges out of the rim but only cosmetic the rest jsut a few nicks here and there.
There is no structural damage and nothing is bent. I want to get them resprayed because I really do like them and have no want for any other wheels.
I'm looking for a place in Canberra that can repair or grind away the chips and gouges before I send them away to get sprayed.
Has anyone had rims repaired in canberra or possibly resprayed or should I be looking interstate?
Cheers,
Andy
https://www.sau.com.au/forums/topic/396613-wheel-repair/
As above rallimax straighten rims, they leave alloy rims with bad surface bruising when removing flat spots etc and they don't deal in fixing cosmetics. most spray shops fix gutter rash and respray rims. I'm not sure if it's wicked wheels but one mob turn up in a big yellow van and take your wheels off, break the front bead of the tyre, mask the tyre and then repair, prep and respray in the back of the van. Just plain old silver alloy wheels though. If you got polished alloy dish or similar your up for some bucks. Spot on wheel repair in unanderra (near Wollongong) are the best in the game at all repairs and finishes.
https://www.sau.com.au/forums/topic/396613-wheel-repair/#findComment-6299335
oh cool. I'd say it might cost i bit for me as they are white volks so i'd say they would need to be stripped after they get repaired. I might give wicked wheels a call this week. I should probably track down another set of wheels to use when i send these away before that though.
https://www.sau.com.au/forums/topic/396613-wheel-repair/#findComment-6299507
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
