what do volunteers get them selfes into?
Straight away you become a rockstar in your SAU Officials vest.
We need volunteers to help with starting off the cars, timing and keeping a eye on the cars on the track.
We hook ya up with drinks and pay for your lunch.
And if you come out with us on saturday night you may find a drink or 2 heading your way.
So if you could help out that would be fantastic.
  • Replies 193
oh wow that sounds like fun but ive never done anything like that before what if i make a mistake or not sure of something? :wacko:
If timing is not your thing i can find something easy like letting the cars in and out of the starting or finishing gates.
easy as mate. Would not put you anywhere you were not cunfortable with.
And if your coming up to watch i can get you right up close to the action.
Its also 1 of the best way to meet other club members.
Good stuff. I'm posting myself on the Mini Wang this time, if there's two spots you are more than welcome to join me and I'll keep you company/show you what to do. Or you might want to volunteer on the skidpan instead as you'll get to be around more people and cars. Either way you'll have a ball.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
