I Have numerous parts stacked in the shed looking for a new home all are in very good condition, will negotiate on prices need this stuff gone ASAP so i can start my new project.
Postage: At buyers expense
Contact: Ben at [email protected]
Item 1: Okuyama Carbing Alloy Pedal Rest and Pedals.
Description: Brand New suitable for race car will fit all skylines R32,R33,R34
Price: $150
https://www.sau.com.au/forums/topic/396798-shed-clear-out-bits-of-everything/
Item 3: Bride Graduation Material
Description: Genuine Bride Fabric, great for doing Door cards and center console's to match seats measures (1500mm x 750mm)
Price: $150
Item 4: Genuine Bride Ergo II Leather Seats and Matching Floor Mats
Description: Like Brand new only used a couple of times they have seat rails for 350Z and the Floor mats are for 350Z as well will separate rails, mats if need be.
Price: $2200
Item 5: HKS GT3037 Turbo kit for 350Z or V35 Skyline VQ35DE Engine
Description: Brand New still in box never used full complete kit comes with everything.
Price: $3200
Item 6: OS Giken R3C Triple Plate Clutch for R32 and R33 Skylines/ GTR
Description: Used has done low km's still has plenty of meat left on it very nice street clutch for high power GTR's easy to use and super strong. Rated to 900hp +
Price: $1500
Item 8: Genuine Cusco Front and Rear Swaybars for R33 GTR will fit other models
Description: Used done low km's, heaps Thicker than standard ones comes with the different bushes and clamps
Price: $400
Item 9: Hankook RS3 Tyres
Description: Brand New 285/35 R18 x 2 super sticky street tyres tread wear rating 140 closest thing to a semi slick you can get.
Price: $500
hicas canceller - will it work on a 32R?
How's the pedal set attached?
Hicas canceler will not work on R32 only R33 and R34s
Pedals are attached with screws and bolts.
