Like Boostmeister says - use the layer mask.
Also use a soft brush. If the OEM ones aren't soft enough, you can 'tweak' them by using the side option menu from the brush-size dropdown (in PS 7)
Jamezilla, good point.
Hiroshima Screamer, if you have problems, send me the pics and I will do it for you [email protected]
PVA, you can do in in PS but its not just a insert and done type of program unlike the software that comes with cannon digi cams "Photostich".
Here's an example of photo joining in PS.
This is what 3 seperate photo's look like when joined, there was actually a fair bit of work in doing this. For those who don't know where it was taken....This is the view from 10 meters out in the water at 6am on a Sunday morning at Surfers Paradise. You have about ten minutes to take the shots you want before it gets too bright.
Black and white is easy to do but there is B&W and there is B&W, I personally like "Black" not grey so you have to tweak the pic a bit. This is done in curves to a good effect.
First though just open a colour bit the go image>mode>greyscale to change it to black and white, just remember that you will not have all effect options available to you to use so mod the pic first THEN GO B&W
Just did it quickly, it all comes down to the images you start with. Make sure they are high res and try and take as many as possible, this is not always the case, it will depend on your camera.
Some cameras expose the shot well while others can make the sky totally different colours, this is when it is hard to blend....sometime I have to almost totally recreate the entire sky
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
