hello everyone selling selling my 1990 r32 gtst with a series 1 r33 rb25, first off the car is an automatic and has 76000kms on the clock i know most of you will call bullshit but honestly the interior or the car reflects this, exterior of the car needs some tlc but everything has been considered in my price.
ok now the good part MOD LIST :D
r33 series 1 rb25 with 120000kms on it the engine has some fruit its been pulled apart and had the bottom end rebuilt with race bearings and the head has been ported and polished
Rb25 turbo rebuilt and hi flowed but never run more then 12 psi
gearbox is automatic but has also been completely pulled apart and rebuilt with drag bearings, shift kits, 2800 hi stall and drag torque converter, truly beatiful gearbox IMO
r32 gtr brakes front and rear and front strutbrace
has a turbosmart boost controller running 7 psi and 12 psi at the flick of a switch
has autometer lunar series boost guage so you know whats goin on
thats pretty much all that i can think of atm,completely open to anyone coming to have a look and with all means you can take it for a spin but i will be going with you and please no tyre kickers or time wasters genuine reason for sale i dont want to sell i have too,
price is $10000 ONO if u dont like my price throw me an offer!
http://s1030.photobucket.com/albums/y367/Confused91/r32%20gtst/
cheers everyone, Chris
https://www.sau.com.au/forums/topic/396960-r32-gtst-rb25/
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
