Finally got my car registered in SA after going through 5 1/2 months of patience waiting for it to be imported. Good impressions so far, pretty fast, boosts good looks good. Only qualms at the moment are:
too low(lowered springs std shocks)
clutch difficult to operate(need time adjusting)
paint requires cut & polish(some swirls and a couple of blemishes)
About the clutch, im pretty sure it isn't standard because my cousins R33 GTR has a softer pedal than mine and mine is rather noisy when it engages. Could it be an aftermarket? It rattles when I press it down and when it engages it squeaks.
A big thanks to both Dean at Ultimate Performace Imports(UPImports) and Rob at Performance Vehicle and Parts Imports(PVP Imports), Dean for doing the brokerage and arranging for the importation and Rob for doing the compliancing and mechanical work. I would reccomend both to anyone doing a similar thing to me.
PS: Pictures of my car have been posted here before, and more to come when I have the time to clean my car! :wassup:
https://www.sau.com.au/forums/topic/39698-my-car-officially-in-sa/
  • Replies 49
You mean you got your car through regency with lowered springs????
What rate are they, if you want some firmer than stock one, but normal height, I might be able to do a deal for your.
Congrats on the new ride. Oh, and normally rattling clutch happens when you have more than 1 plate, so may be a twin. They would tend to have a heavier pressure plate and a more savage bite (well mine does anyways:)). Dont know about squeaking when it engages though? but still a twin plate for nicks, good chance you may have some other goodies as well.
Rest of the car is pretty stock...exhaust is mild steel and no car got complied as a stock vehicle...I need to buy some legal parts for it because the ones that came with the car is too low for my likes. Also have no idea about what rate the springs are.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
