More than likely had a few mods, I mean a GTR that is 15 years old is bound to have encountered some fiddling here and there
The fact that it is still going strong means that whatever it had done to it, was performed properly and has done no real damage, and must have had a owner that looked after it
  • Replies 49
Errr Ok then.
Most 15 year old Japanese imports have been looked after by one mature gentleman owner, who never revved it over 2000rpm on his way to the pachinko parlour and had installed a triple plate clutch to help exercise his new artificial hip. Doctors advice. Get real! Nothing wrong with an old thrasher. They are well cool!
Next you will be telling me that Japs dont knock speedos! :P I laughed hard when the first yard I went to in Japan they had dashes lined up on the bench, winding kays off them. Ever noticed how many imports have 50,000km or 70,000km on them?
If its already been trained to thrash, then count yourself lucky someone in Japan has broken it in for you, and get on with the job of flogging the thing over here
hahah martin i agree with everythin u have written and also tell people that sorta thing. Mate i know my car aswell as almost everyother jap import has been thrashed to death, then us aussies buy them off them :P
Im sayin give the bloke a break thats all. Hes happy to have his car.
I wish I bought an ex drift car - probably would have saved me a bloody fortune in mods
Triple plate clutch, only one reason for that, and who knows whats inside the engine:) God it would be tempting to pull the engine down just to check. How is the idle? And heat shielding.... ah if only they could talk.
Well I guess I wont spare it any 8000RPM launches now :P
Just need to build up the courage, and definitely off street too! (Anyone know any "private" roads? ;p)
Idle isn't lumpy so no cams(or maybe not that agressive), guess I'll find out whats inside when I need to do something...in the meantime, guess I'll just get used to living with the original Godzilla.
Martin: I'm not disilusioned about the wound back speedo, I;m just happy the interior doesn't have any rips and the indicator stalks aren't white and the dash isn't cracked...but it does show its age in the speakers. The rubber surround dissintegrated when I touched it.
As far as I know if it was built to be driven hard, then I will put it to use! (Glad the jap owner agreed too, who needs "posers"?)
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
