  • Replies 55
Posted Images
Located in Canberra here, but I found with the extra boost and a tune over the standard they came on about the same time just harder. Without knowing what you are doing with the car it's hard to say what they will do. Without any mods I would guess they would be laggy, with supporting mods as responsive as standard, with a stroker sky's the limit.
https://www.sau.com.au/forums/topic/397041-5s-on-a-26ltr/#findComment-6306088
There are a few guys with them and the KEY is to get a tuner that knows how to bring them on early and get good results. I'm planning on a -5 upgrade sometime in the future just don't know when the funds will clear up to allow it.
Check in for the next Texi @ Quaker's hill in June and I'm sure there should be someone running a -5 set up. Paul's car (Piggaz) is a 2.8 stroker with -5 and the thing is a real beast (also on e85).
https://www.sau.com.au/forums/topic/397041-5s-on-a-26ltr/#findComment-6306316
Sydking, I was wondering by what are all of these supporting mods you think of using?
Good question
I spose its all the usual though,
Built top and bottom end 26 with cam shafts, intake cam gears ect ect, 87mm cp piston kit, hks step 2 valve springs. Dont really need to name the rest
PFC
3.5" exhaust, Nismo Front pipe and 34 GTR dumps. Decat
34 gtr airbox
Stock gtr cooler
4.11 Gear ratios
https://www.sau.com.au/forums/topic/397041-5s-on-a-26ltr/#findComment-6309371
-5s on a 2.8 with e85 would be very diff to a 2.6 on 98.But yes looks like I'll come check out the texi.
i have -5 on a 26 with supporting mods , check my signature for mods and results , personally think a great set up not as laggy as people think , bit more that std
https://www.sau.com.au/forums/topic/397041-5s-on-a-26ltr/#findComment-6322105
What manifold, dumps and intake set-up are you running? did you port/ceramic coat anything?
Your build list is pretty much indentical to mine but hadn't made the decision on -5 or -7's yet.
and yeah +1 for rpm dyno sheet.
https://www.sau.com.au/forums/topic/397041-5s-on-a-26ltr/#findComment-6322251
standard manifold , Tomei dump pipes , no porting or ceramic coating , I should of got port work done , would of been better.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=360122
should of also mentioned its on E85
https://www.sau.com.au/forums/topic/397041-5s-on-a-26ltr/#findComment-6322776
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
