lol spotted vange thread hahaha
i always wave at guys in skylines, but they never wave bk! OBV NOT SAU!!! sometimes i get daggers n looks. so im kinda carful.
from now on im gona flash my break lights 3 times when i pass a skyline n if they do the same bk then i know they were from SAU!
No love from the country wave! I have seen stacks of skylines lately...I don't wave either..
Using your break lights might not be a good idea. Perhaps try a more forceful wave.. like stick your whole arm out the window and wave! LOL
  • Replies 7.5k
Posted Images
my question is if youve allready passed them how u gunna see them flashing there brake lights :):rofl:
Ok..
Today I saw MISS 33 on Grand Junction Road today at 12pm. I always see her around that time.
And also saw a Calsonic Blue R33 GTR with white rims on North East Road around the same time. Dude was driving like he stole it.
MISS 33 is a friend of mine she's 8 months pregers, drives a wine red s2 33 and is for sale if anybodys interested
She's still selling it eh? Hasn't gotten rid of it yet? It is definitely a nice car and a wicked color to boot! I take it she's having time off from the cafe as I haven't seen her there in a while
when u pass each other, u can c the bak of their car with ur mirros, soo if u flash ur break lights (tapping the break paddle) u will b able to see!
ive waved at guys in lines b4 and they just stare so i dont anymore either :)
I wave but get the WTF are you looking at stare.
Not very nice some Line drivers.
Anywho if u get a young looking kid in my car pictured below it will be me waving or should i say giving u a g'day salute at you.
Wave back if nice and not doing anything else.
Madaz... that looks sweet. I say let's get the ball rolling, how do we get these or have them made up?
Re: Stickers
If we're allowed to make our own stickers up here, i've got a few contacts in the desktop publishing / printing side of things who could help us out. I'll probably need a EPS or high-res gif file to show them.
Edited by Howie
The way that's worded implys she is for sale. How much you think you'd get for her? :(
Re: Stickers
Pretty sure the establishment don't get too fussy about using the logo and wotnot so long as you're not turning a profit off it.
She has had three 33's two red and one black, latest red one for about a year. Maybe your thinking of a previous one, this is only recently up for sale. Trying to convince her to change the plates to MILF 33.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
