Just spotted a blonde hottie driving a midnight purple R33 right off of Hancock Rd. I honestly couldn't say if it was a GTR or GTS-t, was paying too much attention to the driver :)
That would probly be jasmine - jas033 on here i think her username is.
Saw Ricky last night bout 6ish on sth road - the blue 34 thats been on a few sau cruises.
  • Replies 7.5k
Posted Images
Spotted very nice looking Black GTR on gouger street tonight plate was upforit (not spelt right dodgey memory lol). Also saw blksky again last night.
Saw that on gouger st tonight too.. vspec purple 33GTR, UPFORIT plates.. awesome rims. Looked tough as.
Also saw a hot pewter S15 with nice led taillights cruising up and down gouger street.
Lol woops on the colour iam only partially colour blind thats my excuse!
Saw the s15 as well when i was walking back from cibo, were u parked in the central carpark didnt see ya white beast on my travels.
Awww my car feels special now lol :)
not as special as you, you little hottie :P
Just spotted a blonde hottie driving a midnight purple R33 right off of Hancock Rd. I honestly couldn't say if it was a GTR or GTS-t, was paying too much attention to the driver :cheers:
haha.. well it's almost black at night so i don't blame you. I was at cibo's too.. maybe you were having coffee next to me? :cheers:
yep i was parked up in central carpark.. didn't realise it's still free on sundays, free parking ftw!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
