33 gtst - clutch and full exhaust (bellmouth)
Had issues for a while when I fill up tank with fuel and start the car it won't idle correctly and hunts (sometimes stalls)
This issue I was always a bit whatever about it. Hit the throttle and she settles ok.
Major concern is:
I have had a very intermittent issue where the exhaust will pop when I decelerate with no throttle and then touch the throttle it will pop no matter how many times I go on an off throttle. Sometimes it will get so bad it will pop whilst decelerating down revs without touching the throttle.
Through the revs doesn't miss a beat.
Did it with 2 different motors in it. (blew motor) Only things that remained on change of engine was afm, tps, coils and loom. (fuel pump of course)
Cas, plugs, fpr, injectors all changed.
I got consult to find O2 sensor sitting at .3 when cold then when at temp sits around .1-.2V. Had a spare sitting around so tried that and it just read 0.0-0.15V. So I Bought O2 sensor and found readings Fluctuated from .28-.80V. Which a mates car also did. Got better fuel consumption of course.
Car still popped intermittently.
Tested for vac leak and all good.
Tested tps voltage and all good.
Also I originally had exhaust studs snapped so gathered that would cause popping. Changed all studs and gasket. Still popped intermittently.
It was very intermittent so hard to diagnose but of course now I am in QLD on holidays it is doing it a lot more then normal.
I have found that when I'm low on fuel it doesn't pop at all no matter how much I cruise or thrash it. I pull into servo and put fuel in and I pull out to check if it pops and it does.
So I am thinking fuel pump but why or can u guys think of something else?
Sorry for massive read but wanted to give as much info as possible.
I also understand if u all are not in the mood to think as it is Easter and u may be drunk or hungover.
https://www.sau.com.au/forums/topic/397196-exhaust-popping-on-decel-bad/
Also check tps setting.
Did u keep the charcoal canister or remove it? If u removed it wat did u do with the lines? I had a mate route his breather line to the inlet manifold and wondered why it was running rich on decel and accell
Stock bov not blocked.
Exhaust wrap isn't needed for flames lol. It's stock and people think its off tap cause it blows flames.
Charcoal canister lines were put on as they were but will gO over them in the morning.
Checked it couple times as that's what everyone thought it would be and didn't believe I checked it right. It is set at .43v and reads normal on consult when issue is happening.
I'm going to get stuck into it now and see how I go.
One way to check whether or not its the TPS is to turn the ignition off whilst on decel and see if it makes any difference. If everythings working as it should it shouldn't make any difference. Just make sure the motors hot first
Yea that's still the same with ignition off.
I have vented charcoal canister to Atmosphere and it hasn't popped and carried on today.
Will hook canister back up tonight and see if it pops (of it does) then i will undo it to see if it fixs it.
Also found fuel filler fitting loose which is why fuel leaked last DECA.
Just did manifold gasket as I had 8 snapped studs lol. All new genuine parts. Reused gasket to exhaust which was fine.
When it was popping I thought this was due to fix it for sure but didn't :(
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
