  • Replies 69
Posted Images
3000 RPM = 85 HP
3500 RPM = 120 HP
4000 RPM = 160 HP
4500 RPM = 240 HP
5000 RPM = 415 ish HP
5500 RPM = 470 ish HP
6000 RPM = 545 HP
6500 RPM = 610 HP
7000 RPM = 660 HP
7500 RPM = 700 HP
7900 RPM or so = 733 HP
* Going off the brown line
240hp at 4500rpm.....wouldn't want to be taking this thing through many tight twisty roads or traffic. It would feel like a sling shot when it comes on though no doubt. The real shocker is 3000rpm, my stock 10 year old commodore makes more than that at 3000rpm, so just cruising around town this GTR at least in my case would be way too laggy.
Sure the final number is great, about 542rwkw, but for anything other than drag racing, more area under the curve is needed.
Area under the curve doesn't impress most people though compared to a big number, so not a lot of people care which is a shame
Rhe commodore has another 1000cc capacity though
No 2.8l low compression motor that is designed to rev hard is going to be exciting at 3000rpm. Especially when it has big cams etc
Yeah fair enough but also it's a POS and has no turbo.
Anyway, I'm not trying to put this result down or anything, just IMO it doesn't seem to be a very usable car around town. Who knows, the owner may just love revving the shit out of it and good on him cause above 5500rpm it would be moving bigtime and would leave my GTR for dead in a straight line.
FYI Paul makes 201rwhp at 3000rpm, 270 cams, 2.8 etc which is close enough to 2.3 times the power. So yeah has certainly be done.
True!
My 33 made peak torque at 3000rpm can't remember the figure power wise though wouldve been around the 110-120kw range, was a straight line upto 6500rpm :D
Much nicer than the 1j lol
I guess it could also be that if a fast ramp rate was used it would push the curve to the right and make it look laggier than what it is
If you were 'cruising around town' then you wouldn't need to accelerate...so 4th gear at 70KM/H would be fine with low power. And if you did want to accelerate, then simply put it into 2nd (and right into its power band).
Although, I would have to agree that any twisties and it would make a much bigger difference. It's horses for courses.
And yes, zebra, a dyno run may not accurately reflect on-road performance for various reasons - they are really more of a tuning tool.
haha my gtr makes about 65hp at 3000rpm an bout 290hp 5000rpm an only makes 420hp atw 7800rpm pretty sure my car didnt make 100hp at 3000rpm even stocklol if
i wanted low down grunt i'd buy a falcon... but only reving to 6-6.5k? thats a bit gay lol
hmm stroking the engine is on the verge of cheating lol an if ur gunna stroke it why not go an rb30/26... then why not get a 3.2L stroker kit for it... or why not go one step bigger again an u got a 4l falcon engine lol or i did see a gtr with a gen III v8 under the hood with a cpl turbo's hanging off it lol each to their own. an yes in town i would swap for a stroked engine very quickly, as its rather hard to give it 60% a bit at the lights, its either a full on launch or 4wd diesels can beat me if i idle off lol an thats a little embarressing :blush:
You need to come for a drive with me Steveo :)
if you can't drive a car with a 3500RPM powerband you need to stick with your stock commie lol, plenty of fun to be had, just need to know how to change down gears.
you can't compare 3000rpm in a car which is limited at like 6500rpm, and is useless above about 5000, to a car that revs to 8000rpm and has torque to the limiter.
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
