Is this possible can you make it to think there are 2 afm? I'll be using a nistune board reason for wanting a single afm is 1 I'll be running a single turbo and 2 I don't have much room to run twin filters. Im wanting to run afm in cooler piping as well and a single would make fab so much easier
https://www.sau.com.au/forums/topic/397617-single-afm-on-a-rb26/
I recall a thread from years ago, it was either getting a Single AFM on a GTR or 2 AFM's on an RB25, but there was mention of a JAP signal bender thing that could do it
Possibly a SAFC or similar.
Can't remember the outcome though sorry but I have a funny feeling it didnt work
Maybe a single AFM would work as is.
Wouldn't in normal circumstances take the average of both. So why not the average of 1 ?
Sort of like a single 02 in one of the 2 dumps ....
Just to qualify this thought. I dont know sh!t
and to add to this thread not being a smart arse - do we have a search function in this new version ?
Hang on a second... An RB26 ECU was able to start and run my stock R33, simple plug in job.
Why don't you dummies put an R32 ECU in it and switch a couple of wires around. Voila, single AFM ECU.
I mean you don't HAVE a RB26 Nistune yet do you Blake?
The last RB20 ECU I bought was $30
It will plug in, all you need to do is swap a couple of wires and you will have a single AFM ECU in the car. Simple as that.
If I can do it, you can do it.
www.paulr33.com
EDIT: R32 RB20 and RB26 ecu's all use the nistune type 2 board. So you are really at no disadvantage to Nistune an RB20 board. Later if you decide to go back to twins you can just move your Nistune to the RB26 ECU and swap the pins back, making it twin AFM.
Ummmmm simple? Yes.
www.paulr33.com
Ummmmm simple? Yes.
Would need a board reprogramme though
Hey Blake there is a member on here his name is kristafa I think he has a black BMW 318i that he put a 26 into when I spoke to him he seem to be in the know of dos and donts with the conversion
Not relevant to the post but in general still usefull to u
you can use one airflow meter and parrallel up the signal wire to both inputs on the GTR ECU to make it thinks it has two AFMs
the ECU does an average of both airflow meters, so it is basically the same thing
the device you might be thinking of is the later SAFC II that lets you manipulate the AFMs to either single or twin AFM on single or twin AFM car
that is, run twin AFMS on a single AFM car, or run single AFM on twin AFM car
ther other device you might be thinking of is the HKS VPC or vein pressure converter that converts MAP to AFM
This!
Is what I was thinking
that is, run twin AFMS on a single AFM car, **or run single AFM on twin AFM car**
Isnt that the same thing? As joining the signal wires.
I have never attempted this but heard that it couldnt be done as the nissan ecu halves the value's for the afms.
But as u say if u join the signal wire they shoukd read the same any way
I was thinking that to just joining the signal wires I'll be doing the wiring myself and it's my first attempt at anything like this so having everything I need is handy I'll be doing it on Sunday I'll let everyone know if it works
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
