I recently got rear upper camber arms installed on my R33 and I told them to adjust it to 0 degrees camber as it was going to be a street/drag car. But now I have alot of scrubbing problems with my 19x9.5 +38's and my 17x9 +26's? What do people do to combat this but also keep a nice wide contact patch. I will need to get the guards rolled and pushed out if possible but what else can be done?
Thanks
i have 18x9.5 +38 on the rear of my r34 with 265/35/18 tyres and yes they scrub and i have a tad less than 1 degree camber on the rear
your choices are:
-go a smaller tyres size
-dial in more camber
-roll the lip of the guards
im yet to get my rolled so i have lifted the rear a tad so it doesnt scrub much, but ultimately i am going to get the guards rolled
I'm running 3deg neg camber front and rear for the slicks (castor at 5 deg) and so far it doesn't appear to be affecting the street tyres adversely (on my awd Stagea) .
Toe in probably has more to so with "scrubbing". I have zero rear and zero to 2mm toe out front. What's yours?
And as above hard suspension will make both tyre wear and handling worse.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
