Relay will probably work as 0V is normally an earth, but sometimes it is just 0V.
But all is not lost for a dead simple solution. Why not use the Start signal on Pin 42? According to my research, that wire has 9-12V when key in start position & 0V otherwise. Sounds perfect, yes?
DIY instructions:
1) Cut wire on Pin55 a few inches from the ECU connector. Strip ECU end & tape up other end.
2) Strip small amount of insulation from wire on Pin42 (leaving wire intact).
3) Solder Pin55 wire (ECU side) onto Pin42 wire & tape up.
Job done :thumbsup:
Testing & pics are all yours Scotty. I'm not moving mine from where it is as works just fine, but the above is certainly an easier solution....if it performs as expected.
Does anyone know what colour combination wire 42 has
Manual says colour is SB ??
I may have time to check later, but pretty easy to locate it using the ECU pinout diagram. I use the pin positions with NO wires to orientate the drawing.
So you already had a CEL before making this connection?
There was some conjecture whether the duration of the 12V start signal would be long enough to cancel a CEL.
However it was hoped that if there wasn't a CEL, the start signal might be enough to keep it at bay. Do you want to cancel it & see if it comes back in next few hundred kms?
Cut wire 55 and drove great for a few days before cel came on, I have a scanner which normally resets any cel that appears but in this case it doesn't reset even with 55-42 joined. How hard is it to wire up to reverse lights?, is it just a matter of connecting the wire from ecu to wire on reverse lights??
Yes, just take a feed off the reverse lights (check for 12V when in Rev, & nothing when not) & put this into Pin55 on ECU.
Nothing else is required. NB, you may still get a CEL if you go for a long highway drive (I can leave home & not stop for 600km+), but under normal conditions you should go into reverse often enough - or stop at R for a few seconds on way to D, if utilising drive in-drive out parking a lot.
Yep, exactly the same.
Essentially I have this setup (as well as reverse lights) via a key switch.
When on it gives me the valet setting, ie 12V on pin55 permanently, to limit throttle.
When off it operates as normal & CEL is kept off by 12V from reverse lights.
If you had a 12V ignition source on a switch, you could leave it on when you drop the car to the mechanic. Then you'd be relatively sure the apprentice isn't going hooning on the test drive :)
  • 3 weeks later...
What wire number is it. Pin 59 ( 3rd set of pins) is pink with blue trace. 55 (middle set of pins ) is like a red with yellow trace. Is it pin 59 the brake signal in the pin setout a few pages back that I should be connecting reverse lights to??
    • Johnny is sad now... Because you didn't get Bosch Motorsport ABS.
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
