Relay will probably work as 0V is normally an earth, but sometimes it is just 0V.
But all is not lost for a dead simple solution. Why not use the Start signal on Pin 42? According to my research, that wire has 9-12V when key in start position & 0V otherwise. Sounds perfect, yes?
DIY instructions:
1) Cut wire on Pin55 a few inches from the ECU connector. Strip ECU end & tape up other end.
2) Strip small amount of insulation from wire on Pin42 (leaving wire intact).
3) Solder Pin55 wire (ECU side) onto Pin42 wire & tape up.
Job done :thumbsup:
Testing & pics are all yours Scotty. I'm not moving mine from where it is as works just fine, but the above is certainly an easier solution....if it performs as expected.
Does anyone know what colour combination wire 42 has
Manual says colour is SB ??
I may have time to check later, but pretty easy to locate it using the ECU pinout diagram. I use the pin positions with NO wires to orientate the drawing.
So you already had a CEL before making this connection?
There was some conjecture whether the duration of the 12V start signal would be long enough to cancel a CEL.
However it was hoped that if there wasn't a CEL, the start signal might be enough to keep it at bay. Do you want to cancel it & see if it comes back in next few hundred kms?
Cut wire 55 and drove great for a few days before cel came on, I have a scanner which normally resets any cel that appears but in this case it doesn't reset even with 55-42 joined. How hard is it to wire up to reverse lights?, is it just a matter of connecting the wire from ecu to wire on reverse lights??
Yes, just take a feed off the reverse lights (check for 12V when in Rev, & nothing when not) & put this into Pin55 on ECU.
Nothing else is required. NB, you may still get a CEL if you go for a long highway drive (I can leave home & not stop for 600km+), but under normal conditions you should go into reverse often enough - or stop at R for a few seconds on way to D, if utilising drive in-drive out parking a lot.
Yep, exactly the same.
Essentially I have this setup (as well as reverse lights) via a key switch.
When on it gives me the valet setting, ie 12V on pin55 permanently, to limit throttle.
When off it operates as normal & CEL is kept off by 12V from reverse lights.
If you had a 12V ignition source on a switch, you could leave it on when you drop the car to the mechanic. Then you'd be relatively sure the apprentice isn't going hooning on the test drive :)
  • 3 weeks later...
What wire number is it. Pin 59 ( 3rd set of pins) is pink with blue trace. 55 (middle set of pins ) is like a red with yellow trace. Is it pin 59 the brake signal in the pin setout a few pages back that I should be connecting reverse lights to??
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
