Hey guys, i have 2 C33's and 1 A31 getting parted out, they will be available in about 2 weeks, but just drumming up some interest now for anyone who wants to get in early. I will have confirmation on brands and specs of some of the products that are a little vague atm as soon as they get here. I can do these as packages, just let me know exactly what you're chasing and i'll price you up a better price based on how much you grab at one time!
Located neat Mitcham in SA, can post anywhere in Aus!
R33 RB25 Engine - $1900
with Tomei Poncams
(without injectors/ecu/plennum/turbo)
R33 RB25 Engine - $1400
(without injectors/ecu/turbo)
RB25 Manual Gearbox - $1100
Clutches:
OS Twin Plate Clutch (good condition) - $800
Exedy Super Single - $650
Turbo:
HKS GT2540 Turbo (with return line and elbows etc) - $1100
HKS GT2535 Turbo (with return line and elbows etc) - $1000
Garrett T04E (have matching manifold and gate to match, gate specs TBA) - $800
Accessories:
HKS Exhaust Manifold (Stainless steel) - $600
Oil Cooler with Relocation kit - $600
Z32 AFM - $150
Infiniti 90mm Throttle - $300
Nismo 555cc Injectors - $550
2 Layer Radiator - $200
Aluminium Radiator -$200
R32 GTR Intercooler with Piping - $400
Front mount inercooler with Piping - $250
Greddy Plennum - $900
Oil Catch Can Tank - $100
Aftermarket Front Pipe - $100
Lightened Flywheel - $200
GTR fuel pump - $90
Ecu:
HKS FconV Pro Silver - $400
Apexi Power FC w/ Controller - $1100
Boost controllers:
Blitz SBC-ID - $400
Trust Profec B2 - $350
If there's any cool/rare stuff on the laurel shells I'd be interested.
hey mate, there's a bunch of laurel shit coming back, there will be a thread up about that soon, but not 100% sure what's left on it after i got my mate to take a bunch of stuff off before it was sent over for my laurel over there.
awesome, i'm chasing anything thats hard to get over here, front lip, centre console with cupholders,weathershields anything little like that.
Venetians? hahaa
haha i have weathershields on my C33 streeter in Japan, but not sure if i have any coming back, cupholders ill check.
with Tomei Poncams
Clutches:
Turbo:
Accessories:
Z32 AFM - $150
GTR fuel pump - $90
Ecu:
Boost controllers:
Blitz SBC-ID - $400
I was wondering if you had a throttle body to suit my 97 R33 gtst S2?
Do I see r33 gtst coilovers
not sure where dude? the ones in the pic are S14 as you can see by the 3 stud pattern and camber tops, not sure if you mean something else?
Hi there. With regards to the OS clutch, is it a push or pull type? I have a 2WD R33 with a push type clutch and am needing a multiple plate unit due to the power output. Can you please include some pics with the plate wear, heat spots & any other issues. Also - any idea on postage to QLD mid coast?
  • 2 months later...
Clutches:
Turbo:
Accessories:
Oil Cooler with Relocation kit - $500
Z32 AFM - $150
TRUST Intercooler core (rough condition, but works fine) - $200
GTR fuel pump - $90
Ecu:
Apexi Power FC - $1100
Boost controllers:
Blitz SBC-ID - $400
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
