Oh true? I just assumed I needed a full cage, well that will save me abit off time :yes: im hoping too have it ready by Jamboree :wub:
yer don't skimp on the suspention mods man, no good having the grunt if you can't use it for fear of understeer death lol
Haha yeah, true that!
Edited by 51NNA
  • Replies 107
The only reason me and jez put a cage in his drifter is so passengers can enter but I highly recommend something to stiffen the car they flex a lot
well I think for my sake I really should build one lol my metal fab skills are decent enough too do it, i know ile need a notcher because chromoly is a bitch, ile just use a hydro hand bender aswell, have any tips for me mate?
keen to see it finished at jambo, will come inspect myself :)
see we're not such a horrible bunch lol
Haha, i didnt think you guys were, i knew i put myself into that trap, might be able too take you for a lap :yes: and youll get too see how a drift spec cars goes down the quarter hahaha
Seee, when you are not being a cock people are willing to help
I didnt mean too be a cock lol :unsure:
Edited by 51NNA
none of us ever do, but it occasionally happens lol. sounds good man, I've seen a drift spec 180 run 10.8 on slicks so some r deffinetly quick.
make sure to bring the thing to QR for the friday night drift meets awesome laid back scene.
you will learn that arrogance/aggressivness gets you no where fast
this isnt boost cruising
hahaha thats were I started lol have too be on your toes there and straight on the defence!
Cant see mine getting into the 10s, maybe mid 11s and i surely 10s would be over kill power wise on a drifter lol ;) yeah mate ile defently be there every friday night! once its done :cheers:
Edited by 51NNA
It's not a easy job even for a skilled fabricator I'm just lucky and brad shows me the secrets and the extra skills I'm still learning but I'm learning from the best. Now iv seen the way brad goes about the job I would never do one without propper equipment again. To be honest if your fab skills arnt that good I suggest paying someone it could save your life think of it that way plus if there is a cage in the car people will look at it. If you need any help with fab stuff send me a pm and I'll help you out as much as I can.
Yeah ile take it into consideration, i know my tiging skills are shit so i wont be welding it lol, ile just tac it with the mig and take it too a mate whos a pro welder, ile read all the guidelines for CAMS and see whats required. Thanks mate.
sweet man ill cya there, I'm usually floating around there somewhere. should take it to a test and tune pre jambo I'm there 90% of wednesday meets spectating so yer...
+1 for getting the cage rigged up by someone that knows there s#it could be the difference between you wrecking the car and wrecking other things :P
Dude iv played with cars you could dream about I'm not a moron. It sure does but your building a drift car not a time attack car you don't need half the shit your buying chances are the things you replace will cause more to break. If I was building a drift car I would. Kando turbo, nismo injectors, PFC or nistune, decent cooler, e85 and a good cooling system then spend the rest of my 10 g on making it handle and safe then start saving for spares
Tht sounds exactly like a drift car i know :D
I built a full car from a
Rolling shell for around 6.5k that includes buying a motor a box, turbo, clutch, nismo inj, z32, kando turbo on ebay manifold, bsa built the exhaust and cage for it, i tuned it on E85. All u need is coilovers and a shimmed diff and u will mince tyres.
I have learnt over the years what u need and what u think u have to sped money on to hang with the cool kids.
My old drift silvia had everything, all custom knickles etc etc, spent shit loads, this 32 drifter i have now out handles it with just coilovers and steering spacers.
well ive already been drifting in it for a few years with just a rb20- then too the 25, just with a nismo 2 way, tein coilovers and the microtech. I feel ive got the car at its limit with the current mods, so im going too the extreme with it and see how deep the rabbit hole goes lol
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
