The Nismo Intake Collector Part# 14110-RSR45 is what I'm after pls?
This Plenum has been used on BNR32 + BCNR33 + BNR34 cars.
Terry says, "Thanks in advance" > and you reply, "GL Mate!!!" lol
https://www.sau.com.au/forums/topic/398321-nismo-plenum-for-g-t-r/
  • Replies 62
The NISMO RB26DETT Intake Collector is for the true Nismo connoisseur. It has a very distinct design that is only known to Nismo and with this under your hood not only will you feel drastic power improvements (this unit allows so much more air to flow to your engine you will need to tweak the fuel maps) but you will also notice a dramatic change in the under hood look of your JDM Beast!
Currently on Sale at RHDJapan
http://www.rhdjapan.com/nismo-rb26dett-engine-parts-intake-collector-19452
Was: ¥ 183,750.00 Sale: ¥ 152,512.50
Was: A$ 2,186.63 Sale: A$ 1,814.90
Looking at A$1,915.51 landed via ems
Try Marcus as he is usually able to better that price...
All good Tez,
Also beware of dodgy looking second hand units...
The only second hand one i recall advertised on these forums was a std item that was cleaned up and fitted with a nismo sticker...
GL
From RHD website
"Simple bolt-on installation means that no additional work is required (however, the throttle linkage and throttle sensor must be adjusted)"
Although Rich, if you think changing oil filter in stock location is hard enough...
Try getting to all the bolts, water/vacuum hoses & sensors under the plenum while its still in the nuns nasty of an engine bay...
I know a few blokes that have and can do it with the right tools but its not easy an easy feat, esp trying to do it without a few cuts & blood spillage of hands and knuckles...
Thanks Sav, I know what you mean.
if you had the coin would you do this mod and would the benefits be realised in a real life streeter?
Might go check out some threads on after market Plenums ....
"- This product cannot be installed with the engine mounted."
This is an interesting statement as it also says simple bolt on.
What does it really mean ?
Rich, they are suggesting its not possible to install the plenum with the engine in the car - in actual fact it is, just a royal pain!
Good thing I looked at this thread.
I was going to replace my standard one with a polished one, but if this one can't be fitted with engine in, then what chances will I have with a standard one?
Or is this different - fitment wise.
Same/same though oem has smaller internal volume...
Can be done in car with right tools and bit of patience just dont expect it to be an easy job...
Put simply, makes changing gtr turbos/manifolds/dumps look piss easy ;)
Re: Group buy idea...
Ill anti up if we can get em for close to $1K just for a wank factor...
Horses for courses, if i owned a full house circuit/race car and someone sponsered my build id be on it like no tomoro...
They do work no doubt about it...
Nissan Motor Sports Division spent $$$$$$$ in R&D & testing this the final product, but there are more effective mods to be had with $2K for a daily/streeter than fancy bling on the side of your donk... :D
Edited by krayzie32
I'm about completed with mine, so this is icing.
If I can get even better response on the dash 7's, slightly better in midrange too, reduction in heat, then it's Fapworthy
Bring on GB :D
Nismo plenum benefits as discussed on SAU.
This tells me enough - Ta
Thanks sincerely for that link!
God_speed found it interesting too...
particularly since his car came back from Unigroup Eng to-day.
His car has a Nismo plenum in it and Yavuz with the right tune extracted a very noticeable improvement in the bottom end to mid range. The plenum wasn't the only contributor of course, but it's the steepness of the graph that this plenum is supposed to influence.
With regard to installation, Kazu at JapLink with his small hands and right tools has no problem at all in this department. He's installed many back in Nara anyway. I guess it's a gene thing eh? Hehe
Bring on GB :D
Yes I am in pending pricing.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
