  • Replies 126
Just out of interest - found a video with some very intense shuffling...R33 on dynopack....skip to about 40 seconds into video..
so that's what shuffling sounds like .... F**** was thinking what the hell these guys are on about.... .going back to reading mode :)
Yeh i reckon that could be quite annoying and other peeps would ask you every time what's wrong with your car lol!
I've never had it but I'm assuming it doesn't do much harm to anything...although I think someone on here said that it did make their car shudder a bit?
Running-7s, had shocking shuffle, car is otherwise pretty much bog stock. The problem ended up being damage to the front of the exhaust cam, which was resulting in the ignition timing moving possibly 15 degrees. The other issue we found after replacing the cam was that the timing has to be set using a plug lead between the coil and plug on 1, not the loop at the back of the head.
Since fixing these 2 things I have only had it shuffle once, and was testing to see if I could get it, very gently lifting off on small throttle opening. Anyone getting shuffle I can not recomend strongly enough checking basics, like timing..
Wow that sounded pretty nasty what you had there! Well I'll be taking it down to one of the tuners at the coast like Mercury or Godzilla for a decent tune - the people round where I live have no idea on tuning imports, let alone 26's.
Iplen are u running the stock intake pipes?
I am now, I had an aftermarket one but it was leaking, and didn't offer any obvious benefit until I read above about the mods to the turbo pipe, which a/m one had done. Does have an Apexi suction kit and HKS hard piping.
Yeh I read that the stock intake pipework along with the AFM's etc creates enough drag to slow down the turbos down low thus reducing the shuffle affect. If you totally streamline the intake side and the exhaust side you give those buggers free reign down low - spin up way too fast! I think it's the sharp bends and the corrugations in the rubber intake pipes that do the trick....drag and turbulence galore lol
Ok the -7's i just installed and tune have slight shuffle on low throttle loads like slight incline etc has a restrictive 2.5inch cat and made 277kw on 18psi which then led to coilpacks dying on high boost. On 14psi it made 255kw
Nice work! Yeh I ordered my -9's a couple days ago so might be fitting them on the weekend. So what sort of plumbing are you running - you got all your stock stuff still on there including factory BOV's?
Are those npower dumps heaps dodgy?
Lol his car must be much better than the 211kw lolz.
What do you reckon the end result would be with a new cat and coil packs?
Hey just read your sig - I didn't know you have -9's ;) 400 horsies at 18 pounds is quite a nice figure.
That would be my mates car. He's got a intercooler hard pipe kit and other than turbos and dumps its stock.
I told him about that shitty cat. Haha.
Yeh I read on some other forums that it's the removal of the stock bov's and putting in a hard piping kit that does it. The BOV's do some interesting stuff....they actually open to almost half way when you blip the throttle to get some air into the engine quicker by bypassing the turbos. All this gear apparently also stops or minimises shuffle.
But I will know for sure soon as I'll be putting my -9's on with FULL factory intake and compressor to cooler plumbing.
Well, I've observed the bov's doing this myself...not exactly sure how much they influence shuffle down low...they do open down low so they would take some of the air away from the turbos (sucking it back thru the recirc pipe and stealing it before it its the compressor....but after running thru afm offcourse)
The reason why the stock intake piping reduces shuffle is because it generates so much drag inside it's piping (corrugations in the rubber piping, afm mesh etc etc) that it effectively throttles the turbos by just enough to stop them getting too far ahead of themselves which would cause shuffle (too much air for engine to ingest etc)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
