Up for sale are two sets of tyres.
Set 1:
Federal 595 RSR 'street semi' tyres.
They are 225 45 17 all round with a guess of about 60% tread, like below all round.
I am after $400 for the set.
Set 2:
Bridgestone RE55 semi slick tyres.
They are 265 35 18 all round and look to be fairly used but should be fit for another track day or two once warmed up properly.
I am after $100 for the set.
Both sets of tyres are located in the south eastern suburbs of Melbourne.
A local sale of the above tyres are most preferred.
Contact can be made through this thread or via PM.
Thanks
It has been brought to my attention that the set of RE55 tyres are most probably unsafe to be run on track.
Damages to the bead (crack and chips) of some of the tyres have been found and for this reason, I am no longer asking $100 for the set but am now GIVING THEM AWAY free of charge.
The set of RE55 tyres will be thrown out by the end of the weekend if they haven't found a new home by that time.
The set of Federal RSRs are still good to go.
I have finally gotten around to get proper photos of the RSR tyres which are still available.
Set of tyres:
Tyre 1:
Tyre 2:
Tyre 2 with some damage from ripple strips. Doesn't cause vibrations, leaks or anything like that. Good working order:
Tyre 3:
Tyre 4:
Each tyre specifications:
Each tyre's build date are exactly the same:
$400ono.
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
