Just stumbled across this, Made me laugh thought i would share.
It plugs into your cigarette lighter and instanlty save you 20% of you fuel. And saves the earth ahah,
Do people actually buy this shit?
http://www.ebay.com.au/itm/Save-20-Mini-Car-Auto-Gas-Fuel-Saver-Emission-Decreaser-Accelerator-More-/110830622927?pt=AU_Car_Parts_Accessories&hash=item19ce0518cf
anyone else think it works by lighting a light whenever it gets a certain amount of supply voltage due to increased revs, or by the same technologly as iphones and sensing how hard you accerate, therefore making you more aware of your driving style?
thats the only logical way i think it could help with economy.
nope, totally wrong. i found some stuff on the net about them. have a read/laugh for yourself
NEOSOCKET REVIEW
After scouring the internet for fuel saving products and researching them, I finally found the product that lived up to all I was looking for. All I needed to do was simply plug-in the Neosocket into my car's 12 volt lighter/accessory adapter and I immediately began to save money on gas and improved my fuel economy.
Since very few people have the financial resources to convert their cars to natural gas or fuel cell technology, Neosocket has developed a simple and inexpensive way to improve the cars we already drive. The cost of hybrid cars is not at a level we can all benefit from yet, so clever devices like this will definitely make an impact for the millions of cars already on the road today.
You won't need to go under you hood to install anything or disassemble your interior which is always a plus. It has also been proven safe for use in any car that uses a 12 volt system and will not damage your onboard computer.
HOW DOES NEOSOCKET WORK ?
The Neosocket is a new application of an old technology. Basically, it acts like a small battery that helps your car's electrical system perform better. The small device is fitted with a
capacitor that once plugged in to your 12v adapter is instantly connected to the car's main electrical system. (capacitors are also commonly used to power the electronic flash in cameras)
The capacitor first charges and then discharges the stored electricity (voltage) when there is a heavy energy demand from the alternator. Heavy energy demand (reduced voltage) is caused by using any electrical accessory in your car including lights, windshield wipers, air conditioning, stereo or any combination of them.
Instead of the alternator and battery having to work overtime, Neosocket supplements the required voltage to reduce the load on the electrical system from any accessory that is being used. The reduced electrical demand frees up energy that can be better used to deliver a more constant and steady supply of electricity to the spark plugs and ignition system.
The result is a more efficient and complete combustion of the gasoline which will improve you gas mileage and produce cleaner emissions. You will also get better horse power, acceleration, and a smoother running engine despite daily driving conditions.
The fact is that fuel mileage will fluctuate in any car due to driving habits, lack of maintenance, traffic conditions and many other factors. All these factors will rob the fuel efficiency your car was meant to achieve. The main purpose of Neosocket is to help your engine consistently maintain its designed fuel efficiency despite of all these unpredictable situations.
basically they say it's a capacitor that supplies extra charge to the electrical system, taking strain off the alternator. unless you have a dynamo off a pushbike in the place of your alternator, and a few AA batteries in the place of your car battery, i doubt you will see any difference in fuel economy.
seems legit :ninja: , also all p plater should get this if that claim is true.
so whos stepping up and testing this for sau?
surely there has to be some law against shit like this???
i honestly cant believe that 7 people were dumb enough to buy this magical fuel saving dildo
There is a law against it. A law that has very severe consequences...
I believe it is called natural selection.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
