FOR SALE "my dream car"
R34 GTR M-SPEC (rare only 228 built)
only 56,000kms
Motor only done 6,000kms since build
All work carried out by Croydon Racing Developments
Motor is the full JUN 2.7 race catalog (same set up as the JUN R32 and RH9 R34 claimed their fame with 1000+awhp)
JUN Plenum
CRD JUN race head
CRD 9litre baffled sump
Run in on HKS TO4Z
GReddy alloy radiator
GReddy drag intercooler 160 wide
Tein coin overs
OS Giken quad plate clutch
genuine Titanium exhaust
Volk Gram Light 57F Pro 19x10.5 Pro GOLD
motor is ready for big turbo set up and to go over the 1000hp I was going to 1300hp. That is if the new buyer wants more power
currently 430awkw on Shell 98oct
Motor has never had any higher boost or race fuels.
Any doubts about the car feel free to speak to the guys at Croydon to confirm genuine kms and build was no expense spared.
accident free history
Rego NSW Jan2013
Regretful sale but both toys are going, my R33 GTR V spec 'WAR33R' will be up here next when I get some pics
NO LOW BALLERS or TYRE KICKING TEST PILOTS
$98,000
Justin 0414894884
https://www.sau.com.au/forums/topic/398787-r34-gtr-m-spec-complete-jun-set-up/
Yes the 33 is still available. Although It might sell before it gets on here as theres already been a few offers....not to many cars have passed EPA & DECCW and be engineered for the the big single, front mount and airbox.
more info on the R34 GTR M-spec:
JUN 2.7L stroker kit
JUN 280deg. camshafts, retainers and valve springs
JUN oil pump
CRD 9L sump
ARP head studs
JUN main studs
competition engine bearings
Gates timing belt
Mines cam baffle plates
JUN vavle guides
Head fully race ported & polished + machined for oversized valves
ROSS harmonic balancer and pulleys
HKS TO4Z turbo kit
JUN plenum
90mm Infinity throttle body
Ferrera vaves & locks
SARD 1000cc fuel injectors
SARD fuel rail
TRUST 165 wide drag intercooler
TRUST alloy radiator
CRD spec water pump
TRUST blow off valve
I'd say you can guess close enough the rest.....car has over $80,000 in mods alone
all with only 6000kms on them,
for those that asked to separate...... $45,000 for the motor
and non refundable deposit before its removed
Car will then be returned to stock $75,000
So yes cheaper to buy as it is but up to buyer I guess
Keen to part with the front seats?
Yep keen to part with front seats but only if you buy rear also. I'll sell them to you for a one off special price $98,000 and will chuck the car in with them for free......
Sex right there, ur gonna regret selling your dream car
I finally got into my 1st GTR "WAR33R" after defeating cancer. I always wanted a tuff all rounder (street, drag & track car) and could look no further then a GTR how ever I truly wanted a R34. Now I have finally full filled my dream 2 times over with my R33 NITTO build and R34 JUN build, only to now be having eye issues. This year I've already had 3 surgeries to re attach my retina try this out
and BTW your awake the whole time. Unfortunately due to this I'm not able to keep cars. Both builds where from built to handle a lot more then I have had the chance to give them but unfortunately they don't pay the bills so since I can enjoy them anymore they must sadly go.
  • 3 months later...
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
