17" Advan Racing Rims (17x8 and 17x9) needs new tyres= $1350
r33 series 2 wing silver = $170
r33 snorkel = $20
r33 Air box = $70
r33 original floor mats = $140
r34 turbo timer with harness (ultra automated timer) = $80
r33 turbo timer with harness = $80
Stock soarer font bar with lip (blue) = $100
205/55/16 x 4 Falken Ziex (Brand New) with Purchase Receipt = $450
225/45/17 Sumito 80% thread x 2 = $60/each
16" (5 stud off skyline) pursuit rims with snow tyres = $350
17" (4 stud) no tyres = $400
Kenwood Double Din Headunit with 12 Disc Kenwood CD Stacker (Silver) = $690
Pioneer Double Din Headunit = $490
r34 Xenon Headlights = SOLD
r34 original floor mats = SOLD
Stock r33 rims (no tyres) = SOLD
Stock r33 suspensions (one has oil leak)= SOLD
Stock r33 Springs = SOLD
Lowered King Springs (r33) = SOLD
r33 front strut brace (with blue handles) = SOLD
Momo steering wheel with r33 boss kit = SOLD
Blitz Boost Gauge (bar reading - white face) with holder = SOLD
255/40/17 Bridgestones 90% thread x 2 = SOLD
Clarion 12" 600watt (Brand New) Paid $300/each 3 months ago = SOLD
More info and Pics request to [email protected] or pm me
Everything in Brisbane - Will cod & freight interstate
  • Replies 49
series 2 wing is the elevated one ... As you can see on the pic it should be different to ur's - if ur's is stock. Yes it comes with a brake light, can give you another one one on top from another stocko wing.
hey bryanlee
where abouts are in qld??
is the HKS SSQV avaliable for pick up??
the r33 adaptor is the same as r32 isnt it??
how much use has the BOV had?
VEY interested in that raised wing.....
it should just 'bolt on' where mine is right now? there was no boot shape changes from serious 1 to 2 i don't think...
i'll take the wing, but only if you will hold it until next week (or COD it to me and i will pick in up next week...)
  • 4 weeks later...
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
