Hi guys and gals,
just a quick question after installing an apexi pen style turbo timer and was wondering if anyone knew how to program the O2 and AFR part of the timer as the instructions with the timer aren't that clear. any help would be great. ps its for a series 1 r33 gts-t 94 model.
cheers chris
Hi guys and gals,
cheers chris
There is no programming. It's as simple as getting a pinout diagram of the ECU and then tapping into those respective outputs.
You don't need one. Uninstall it and buy something useful.
This. Listen to it. I have one and I dislike it immensely. Used to think it was cool and that everyone thought I was badass. My have even thought it served some remote purpose. But it's not, nobody does, and it doesn't. They are just annoying and they cause problems. If I could be bothered ripping it out then I would, but it's no longer working anyway so I just leave it there.
Mine is generally switched off in most cases but is mounted right up in the upper right of the windscreen, nobody see's it and its of no bother :) Most trips in the car wouldnt warrant having it on...
ok from what im gathering the af and O2 function are just wank, set the timer and be done with it! cheers thanks guys.
Martin, i spliced into the loom at the right connector just doesnt want to work. just wondering if my o2 sensor is shot because the autometer guage never reads accurately as well.
any way thanks for the info and feedback gents.
Is the Autometer a wideband? If not, then it will never read accurately. If it is, then that's why the O2 sensor function won't work, they only work with the stock narrowband signal.
martin its a narrow band guage but its never raed accuarately only maybe once or twice in its life. i also connected the apexi time directly to the o2 sensor loom in the engine bay and went for a fang never got above .5v which makes me start to think the sensor may be stufed. the motor does have over 320K on the clock. but still pulls hard and drives well. whats the average life span of an o2 sensor anyway? any help would be greatly apperciated.
cheers
cheers
Well what do you consider accurate? The only thing a narrowband gauge will ever do is flick from lean to rich. Off the top of my head, the sensors operate between 0.4v and 0.8v; but will typically be at around 0.45v. If it's not showing over 0.5v, you may have a stuffed sensor, or the gauge you are using is junk, which wouldn't surprise me.
If you are getting any semblance of decent fuel economy, then it won't be a stuffed sensor.
car still gets around 550km if nursed or around 400km if flogged per tank. only has rebuilt turbo (roller bearing and steel ex turbine and blitz nur cat back exhaust. so i guess i just got sucked in by the techno wank factor :rant:
:cheers: cheers thanks for the help
Dont install it man, just dont flog it for 10mins before you turn it off, there the biggest wank factor out and it makes your car ALOT easier to steal.
Even 10 minutes is a lot of overkill. 1 minute is plenty.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
