R33 R34 GTR Nismo titanium strut brace, ultra light, strong and quite rare. $1400
R33 GTR Guards, with guard raisers, indicators and badges $430
R33 GTR Bonnet, with bonnet hinges & latch $350
R33 GTR standard front reo, $150
R33 GTR Tommy Kiara GTR front bar, brand new genuine TK, $600
R33 gtst gtr style rear pods, painted white qm1, few scratches $200
R33 GTR N1 bonnet lip in carbon fibre $100
R33 GTR rear wing carbon fibre (real not fpr) blade $350 due to inperfections
R33 GTR ARC induction box with filters, is missing the metal cover (not hard to fab a new one) $400
R33 gtst/gtr rear strut brace $80
R33 Nismo clutch slave Push type 30620-rs580 $140
R33 GTR clutch booster $80
R33 climate control unit $20
R33 gtst dash cluster, white face,101xxxkms $100
R33 centre console $50
Nissan BM-57 brake master cylinder $150
HKS 2530's with hks actuators, few thousand kms on them, missing a few studs and a c clip off the actuator. $2000
R33 gtst S2 headlights, pretty good condition, has been plastic welded on the back. $400 pair
R33 GTR front drive shaft $120
R33 GTST S2 steering wheel, (no covers) with airbag $180
R33 GTR / GTST carbon look gear stick and hand brake boots $50
Set of Yokohama S-drives 265/35/R18 $650 set of four.
R32 GTR front windscreen non genuine, 100% clear, no strip or antenna, new $150. (cannot post this one)
R33 gtst drivers guard, scratched but straight. $80
R33 GTST S2 Tommy Kiara $400
R33 GTST S2 fog light indicators L+R $100
Exhaust heat wrap $80
Brand new Whiteline Subframe align and lock kit- KCA349 $120
Brand new Whiteline Caster correction - radius rod to chassis bushing $130
Brand new Greddy full auto turbo timer suit r33 gtst $100
Brand new Black RAYS wheel nuts and locker suits nissan $270
More parts to follow next week..
Parts are located near Parramatta NSW, postage can be arranged at buyers expense.
Cheers
Johno
0401466244
Pm sent KamikazeR33.
Titanium brace sold pending payment
BM57 SOLD
Gtst cluster SOLD
Climate Control SOLD
N1 Bonnet Lip SOLD
R33 GTR standard front reo, SOLD
Ruzic 4WD controller SOLD
dont forget to send me a video of the 2530s shaft play. im very keen on them!!! consider them sold pending video
BM57 SOLD & posted
Gtst cluster SOLD & posted
Climate Control SOLD & posted
N1 Bonnet Lip SOLD & posted
R33 GTR standard front reo, SOLD & collected
Ruzic 4WD controller SOLD & collected
Tommy Kiara S2 GTST front bar SOLD
GTST S2 indicators SOLD
Yoko S-Drive's SOLD
BM57 SOLD & posted
Yoko S-Drive's SOLD
Nismo Titanium brace SOLD
R33 GTR Guards and Raisers SOLD
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
