Im currently parting out my R34 GTT with GTR runing gear. everything must go.
R34 GTR parts as follow
Gatrag 6 speed gearbox, perfect working order, good meat left on 4wd transfer case. comes with pull type AND push type fork and slave cylinder, 5month old nismo gearbox mount, and support brace, complete with GTR shift knob, AND front prop shaft: $4000
R34 GTR Year 2000 V-spec turbo, perfect with no shaft play $350/pair
STD GTR injectors $200/for 6
Pearl White GTR aluminium bonnet, minnor dent on the front area, fine as is or just a touch up: $500, bargin!
R34 GTR Tail shaft: $200
Light weight flywheel (7kg) and exedy heavy duty single plate clutch: use less than 9 month with light foot, never launch, just bed in. paid $1600, pull type $800
Vspec dash cluster, 25xxx or 26xxxkm on the clock (Rare very low K), no clouds, no marks. Perfect!. $200
Apexi boost controller. with leads. $50
front subframe, $150
Uprights: $150 ea side
Lower and uppper arm: $120 ea side
Steering Rack, 2.5 lock to lock : $150
Sway bar: $50
Front Shaft $120 ea
Or the whole front suspension setup $900
Std R34 gtr intank Fuel Pump. higher flow than pervious model, support up to 280kw awkw no worries, $120
V-spec very little k's travel. $650
V-spec hydroic pump assembly, wiring hardness been modified, suit spare $200
STD rb26 AFM $100
GTR twin turbo 60mm into 70mm front pipe. mines style, very good flow probably the best twin front pipe design. $250
34 gtr fujisubo Full exhaust. Jasma Approved. flows very well and very quite, 80mm main pipe, made over 300kw with this pipe before. $350
CATCO 3" High Flow cat, Brought for $200, selling $80
OEM R34 GTR sideskirt with front guard lower skirt, RHS minior twisted $250
GTR replica full carbon fiber rear wing with OEM height (custom requested for oem height) $350
R32/33 GTR parts:
R32/33 Apexi Power FC, complete with hand controller. a minor scrach on the hand controller but wont affect the readding at all $750
GTR BOV $120/ pair or $70 each.
R32 intercooler $70
Thick full alloy radiator 8 months old, suit R32 $80
Item located doncaster east Melbourne.
PM call or text 0433289998.
cheers
joe
Edited by godsmind
some pics on this thread
http://www.skylinesa...66#entry6333066
Boost controller is actually solenoid only. no actual control unit. sorry for the miss leading.
V-spec R34 diff very little k's travel. $600
Will upload as much pics as i could.
Edited by godsmind
Right hand Upright: $150
Right Lower and uppper arm: $120
Sway bar: $50
Right Front Shaft $120
V-spec Diff very little k's travel. $650
STD rb26 AFM $100
R32 intercooler $70
  • 1 month later...
  • 4 weeks later...
Sway bar: $50
STD rb26 AFM $100
R32 intercooler $70
hey man do u still have the lower controller arm?
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
