SPEAKING OF WHEELS,
If anyone can track down a set of Bee*R b5 wheel stickers i will be eternaly greatful. Case of beer (or whatever you drink) to the person that can track a set of down.
SPEAKING OF WHEELS,
Are these them? http://www.rhdjapan.com/pinpoint_result?keyWord=Search+keyword&pp_manufacturer=Bee-R&carMake=All&carModel=All&carDetail=All&x=26&y=14
Bridgestone/ tokico potenza street suspension suot r33/r34 currently being stripped and cleaned with new dust covers fitted. Excellent hanfling and superb ride quality. 350mm rideheight. $300
Pay day is next week - I'll hit you up around then. Is 350mm high rider? Or just legal?
Edited by RosieR34
Its about 20mm lower than stock all round but is not illegallylow. Went through dickson and a canberra mechanic inspection with this ride height
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
