Hey guys,
I just had look through a few threads I found using the search button, but sifting through couldn't find what I was after.
Looking at purchasing a Blitz Spec-R exhaust system for a '93 R32 GTR. Then I had a think about getting one made. For the same price (~1k) would it be possible to get a decent system fabricated? Is it a better option over the Blitz shelf system? What are your experiences with using shelf vs custom systems?
Any thoughts views advice welcome,
Thanks!
Generally you can get them quieter going custom as well, which is a concern for a few people hence going that route.
Also Jap off-shelf systems often have internal reducers/restrictors. So they say they are "90mm", but half way there is a shitty step down to 2.5-2.75" to try and help with noise reduction. Something to be mindful of.
Custom is way better in my opinion. For me it's the clearance. When you have an exhaust custom made for you, they can make it sit off the ground as much as possible. I don't have any problems with my exhaust scraping, and my car is very low. Sometimes the flange or the heatshield on the cat scrapes a little bit, but if I went with a custom dump/front pipe then I could sort that out as well.
im in the process of making my custom 90mm exhaust for my r32 gtr, no step downs anywhere ! even the mufflers are 90mm right through...
as above, the jap ones usualy start off at 70 or 75mm inside diameter at the cat flange, then open up to 90mm before shrinking again to somtimes 65mm in the rear muffler....not good for power at all :/
I'm in the process of custom right now with my GTR, and 'top of the line' bolt on with my BMW. So far I'm happier with the custom system on my GTR. A couple other pluses with custom:
-better fitment (at least it should be with a decent fabricator)
-v-band flanges
-extra features such as 02 bungs
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
